Question about Maytag Neptune FAV6800AW Top Load Washer
Can i by pass the rf filter it didnt have a elec cord can i just hook elec to the plug that was with the rf filter
  • 526 Answers
I haven't done it no reason to date why do you need to bypass. Have you lost 120VAC thru the filter.
A pic to make sure I'm on the right page with you.
I measure almost no resistance thru the line filter. Do you measure an open.
If you are going to bypass you would have to make up a cheater cord plug directly on to the Control Board 120VAC input.
On the schematic that woule be Conn_P6 Pin1 for L1 120VAC hot and Conn_P6 Pin 3 neutral.
Do you have the schematic from the troubleshooting guide which should have been in the console?
Rich
Posted on Oct 25, 2010
  • FAV6800A FAV9800A
    FAV6800A FAV9800A Oct 25, 2010
    Sorry I should have looked at your issue I'm in left field. Maybe you can make up cord with female spade lugs and secure it to the washer then run thru the line filter.
    I assume this is a machine you recently picked up. I would get a appliance cord and put spade lugs on it and connect to the RFI filter. You may need a bulk head grommet if the machine is missing that.
SOURCE:
How do we hook up VCR to TV
  1. 1
    Turn off all of your components. This will help prevent any accidental damage while connecting.
  2. 2
    Connect the RF/COAX Out port on the VCR to the RF/COAX/ANT In port on your TV. Use a coaxial cable.
  3. 3
    Connect your antenna to the the RF/ANT In port on the back of your VCR (optional). This will allow you to watch over-the-air broadcasts through the VCR.
  4. 4
    Turn on the VCR.
    • Make sure that the VCR is plugged into the power outlet.
  5. 5
    Set the VCR channel to Channel 3 or 4.
  6. 6
    Turn on your television to the same channel that your VCR is set to.
  7. 7
    Start playing your tape.
or check this site:
How to Hook Up VCR to TV
May 19, 2016 | Televison & Video
I have a maganovox combo system, converter box, older model zenithe tv and rf modular. How do I connect all this to record and look at vcr on combo? I need step by step of hooking up all cords and plugs....
You dont need the rf modulator. Use a female to male rf, antenna cord and plug from the RF out on the back of your combo to the TV. Now you need to tune your TV on analogue mode until you find the dvd/vcr picture. Have the combo on when you're doing this.
Feb 19, 2014 | Televison & Video
My cord is broken off the rf unit
You could buy a broken Sega genesis console off of eBay and if it has parts that work you could swap parts From the broken Sega genesis console and put them in your guys console it requires soldering and a buy pass plug from radio shack and. Has a high rate of not working if you don't know how to fix it. It would be better to buy a new one then and sell yours broken on eBay.
May 29, 2012 | Sega Genesis Console
We are trying to set up an old super nintendo we have rf adaptor hooked up and its set on right channel but its not showin on tv
probly the connection in the rf adapter is crapped out. there is a cord that is sold with the n64 and gamecube( not sure about the wii) that can connect to the super nintendo. kind of a rounded rectangle plug with a bump at the top that has rca cords ( 3: 1 for video and 2 for sterio sound). look at the back of the nintendo and ull see what im talking about. there should only be 2 outputs. the rf and the other rectangle with a dump one.
the other cord was never sold with the super nintendo just the rf was sold with it.
so if u have a N64 or gamecube you can use their tv input cords
Oct 25, 2010 | Nintendo Video Game Consoles & Games
Can you hook up a super nes without AV cords? I have 2 cords, 1 is power and 1 connects to an antenna-like input.. do you need AV cords aswell??
It is called an RF connector.Plug your cable coming into the house from outside into the RF connector,then plug the RF connector into the TV.The TV needs to be on channel 3 or 4,depending on what it is set on the console,to use the console.There should be a selector on the console back.If there is a strong broadcast on the channel you select to use,just change to the other channel.If you have the proper channel,the TV signal will go away and the game will appear.You do not need the A/V cables.
Jul 23, 2010 | Nintendo Super NES Console
I had the adapter plugged into the socket. And the other cord in the back of the NES but I dont know where to plug it in? The only place it can go into is the back of the dish network receiver. is that...
The RF adapter is supposed to hook up to either your TV or VCR. If neither has a plug that fits, you may need an RF modulator. (I don't think the receiver port would work, but I'm not positive.)
If you have a audio/video cable (you can get them from a dollar store depending on where you live) and a y-splitter, you can use the ports on the side instead. Hook the video straight in and use the y-splitter to split the one audio cable that fits into two and hook it up that way. (This method assumes you are in an NTSC region such as North America or Japan)
Whichever method you choose, good luck. (If you have a VCR with that plug, you don't need an RF modulator since the VCR will do it's job.)
Oct 01, 2009 | Nintendo NES Console
I cant get my dvd to play using my rf modulator
instead of plugging in the rf modulator before the cable box, i plugged it in after it
Jan 24, 2009 | GE 25GT240 25" TV
Sega mega drive - how do I plug it into tv?
Ok, a few basics to hooking up your console. Firstly you should have two cords a power cord that plugs into the wall and into the back of the console. Another cord should also plug into the back of the console and the other end should be plugged into the back of the television into the slot called in. However if this plug is already taken by a vcr you can hook the cord from the sega up to the vcr in port. After it's all plugged in and the console and tv are on and it's directly hooked up to the tv then change the tv channel to 3 or 4 and you should have something on one of those channels. However if you hooked it up through the vcr then you have to go to the channel that normal has your vcr then change the channel on your vcr to 3 or 4. I think this is all you need to know good luck.
Nov 01, 2007 | Sega Genesis Console
Problem with NES
Check on the back of the nintendo system if it is on same channel as tv, little switch is on the back next to the power cord.
example..tv channel 3 and nintendo system channel 3
If that doesn't work your cable is not properly connected, You can't use both rf switch and av cable. It one or the other. rf connect in the back and to coax cable. Av cable connect on the right side of the system and front input on tv..
Make sure your games are clean also. Good Luck.
Sep 17, 2007 | Nintendo NES Console
Maytag Neptune FAV6800AW Top Load Washer Logo
57 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
