Question about Toro Electric Trimmer
I can't get the spool off of my Toro 12 inch trimmer model 51325. I have tried all the suggestions on the web site and it won't come off, however it came off my itself earlier when it ran out of string while I was using it. I wound new string onto it and put it back on, then it wouldn't come off seconds after I put it back on!! what's the trick?
    President:
  • Toro Master
  • 1,545 Answers
You are doing well. The Toro site states that this is a model from 1985. User manuals were much more concise back then and so I will have you view yours. Click on the link on the left that states:
Toroe Electric Trimmer/Service Manual (English). I have viewed it and spool removal instructions with pictures are there.
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#manualsResultPage
Posted on Oct 24, 2010
6ya staff
SOURCE:
Toro 8 inch cut home duty trimmer how do you remove the spool
You have to hold in the two tabs at top of spool assembly
Aug 30, 2012 | Toro& Electric String Trimmer
My Toro 12" Trimmer (Weed eater) needs a new screw down cap to hold the spool in place. Home Depot no longer carries them. That's wheree I got the last two Weedeaters.Please give me instructions as to...
Your Toro electric trimmer parts are readily available through www.partstree.com . However, to avoid having to pay $10 in shipping for a $5 part, you should try to find your local Toro dealer. They probably have the part in stock. Go to www.toro.com and search on the dealer/distributor locator to find your closest dealer.
You will need to know the model number (5 digit) and serial number for your trimmer. These can be located on a small sticker on the trimmer.
Oct 14, 2010 | Toro& Electric String Trimmer
Refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Apr 11, 2010 | Toro& Electric String Trimmer
It has come apart and I would like to refill the line on my toro heavy duty electric trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 23, 2009 | Toro Garden
I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Jun 03, 2009 | Toro Electric Trimmer
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
May 26, 2009 | Toro Electric Trimmer
Cannot undo the string compartment to put new string in. There may still be string in the compartment but I cannot get into it. This is a 12 inch Toro electric wacker.
There sould be a knob that turns counterclockwise to take spool off. If not there sould be two taps that push in and pull down on what they call the spool head. Hopefully this will help you.
May 14, 2009 | Toro& Electric String Trimmer
I have a Toro 12" electric weed eater and the line needs changed. Both of my brothers, my brother in law and my son have tried to get the bottom off (where the line goes) but it will not move. They tried...
If the knob on the spool has two small rectangular slots on opposite sides, try inserting screwdrivers in each one at the same time and then turn the spool slightly. This might allow it to pop off.
Apr 25, 2009 | Toro Electric Trimmer
Toro Mdl. 51325- Ser#-0013490 Electric Trimmer- Drum w/eyelet Replacement
You simply hold the Drum steady and twist counter clockwise on the center piece with the spring and all. mnremoves pretty easy.
Sep 27, 2008 | Garden
Toro Electric Trimmer Logo
532 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
