Question about Belkin (F6C550-AVR) (DBF6C550AVR) UPS System
For a Belkin F6C550-AVR: (1) House
For a Belkin F6C550-AVR: (1) House experienced a recent power failure. (2) Surge-protected only outlets are live (120V). Battery backup outlets are not (0V). (3) None of the front panel LED's turn on. Holding On/Off/Test switch down results in a single beep about every 2 seconds, even when unit is NOT plugged in. (4) A slight click is audible each time unit is plugged in. (5) Multimeter shows battery at about 6V. (6) Pressing the circuit breaker on the rear panel has no effect. Is there an internal fuse that might have blown? Are there any other ways to test the system, e.g. with a multimeter, other than buy a new battery and hope that was the problem?
  • Belkin Master
  • 7,733 Answers
SOURCE:
My belkin F6c-500 works on the non back up side however, doesn't work when power is lost. I have replaced the batterey.
Moss Fet Transistors Failure.
When an UPS works too Much time power line disconnect always the UPS only works for a while. too much time working with the Batteries inside makes the power converting transistors overheating and failure.
Check Internal Fuses, inside the UPs there is an automotive Fuses(30 Amps) plug tipe like in cars.
if the fuses are OK .........................then check it by a Technician.
Check it by a Qualified Technician and check the Mossfets.
Sep 27, 2014 | B&B Belkin 84Whr F6C550-AVR - Rev.A UPS...
How do i tell that my UPS batteries need to be replaced
UPS makes self simpler tests regularly, if problems arise alerts UPS.
You can break the input voltage to the UPS and have it run on battery for 20 minutes, if your load accept the risk of power interruptions ...
May 23, 2014 | Belkin (F6C550-AVR) (DBF6C550AVR) UPS...
How do i change battery in Belkin 550av
I have had the same problem with mine.. and just found the product manual for BELKIN'S F6C550-AVR - UPS.. this is the link.. I hope it is helpful
http://www.belkin.com/support/dl/614-07166-00_UPSmanual.pdf
Jan 30, 2012 | Belkin (F6C550-AVR) (DBF6C550AVR) UPS...
My Belkin 550VA don't start up The model is F6C550-AVR
this may happen because of gone battery without battery it will not comes on mains also so directly change battery before that you also check the fuse if blown replace it with same ratings problem will be solved
Feb 24, 2010 | Belkin (F6C550-AVR) (DBF6C550AVR) UPS...
How do I know when I need to replace the battery
The only thing you will look out for is the specs of the battery. That is the voltage that it gives out. The size usually determines the hours it can provide power on a full charge.
Dec 11, 2009 | Belkin (F6C550-AVR) (DBF6C550AVR) UPS...
How do i secure my belkin 54g router? we only want people who are in the house to access it
Go to the setup page for the router (IP 192.168.1.1) and set up the WPA-PSK [TKIP] security. It will allow fairly simple setup, and only provide the pass code to house members.
Nov 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin f6c750-avr repair / Testing
You could be correct on the transformer. I'm kinda leaning towards a bad cell in the battery. Sounds like it will need replacing.
Sep 03, 2009 | Belkin (F6C750-AVR) (BELF6C750AVR) UPS...
UPS periodically disconnects
You have a smart chip problem. Your unit is too small that would be cost effective to repair.
check out my web page:
www.storminprotection.com.
I will help you save a few dollars but I think you might need a little bigger UPS then a 550. Try going bigger.
Mar 14, 2009 | Belkin (F6C550-AVR) (DBF6C550AVR) UPS...
Denon AVR 2106 amp failure
Does it still power up for a little bit or so with no sound what so ever?....I there is no dents in it or metal pushed in causing cracked connector boards....I can take it off you hands for a couple parts I need ...because your transformer and 2 resisters are shot and it will cost almost as much as the unit cost's.
I do have a brand new never opend $649.99 Denon AVR-788 for $365.00.
And 2 used AVR units Denon and Onkyo.....ALL HDMI
call 630 742 6587
Aug 30, 2008 | Denon AVR-2106 Receiver
The AVR-3300 power-off to stand-by mode
You have a blown amp or a leaky cap and the unit is going in to save mode to avoid destrying the unit.
Take it in for a repair. I don't think it should run more than $50-$75 for a fix depending on what component is bad.
Nov 19, 2007 | Denon AVR-3300 Receiver
Belkin (F6C550-AVR) (DBF6C550AVR) UPS System Logo
294 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
