Question about GMC Denali 700C Road Bike
I had to replace my twist shifter cable for the front deraileur. A small metal "V" shaped piece dropped out, how do I put this back in and at what position.
  • Anonymous Mar 18, 2014
    The cable snap how do I put it back
    New Friend:
    Problem Solver:
  • 8 Answers
Those are pretty tough to replace... The shape of the plastic shifter case should be your guide- there's a little nook that the v-shaped metal sits in. I *believe* that the side with the little bump-out goes towards the middle of the shifter- but you could look for what's called an "exploded diagram" of your shifter online (use the numbers & letters on the shifter for your search). Then you have to line up the two parts correctly (with the number 7 on one part at the little white line on the other) and twist them back and forth just a little bit while you push them together. Sometimes those little guys are impossible to put back together once they've come apart. You could find a cheap replacement for around $25- or try used!
Posted on Dec 06, 2011
SOURCE:
I have just installed my first set of SRAM shifters (2010 Force). The back (right) one did fine; however, the front one (left) shifts fine from the small chainring to the large, but going back down it is...
before you install the cable shift it in the position of small ring ,then insert the cable pull it and tight the screw in the front deraileur(left lever)to it same to the right
Jan 30, 2010 | Sram Force Double Tap Shift/Brake Levers
How do I replace shifter knob on my 2001 grand am, I got new shifter knob but no instructions on how to get old one off and new one on?????
If you look on the front of the knob there should be a small **** there. If you take a small flat headed screw driver and put it in there at a 45* angle you can gently pry out a small "bail". It's a u shaped peice of small metal. Like a paper clip bent in a U shape. Pull that all of the way out and pull up on the handle.
Oct 15, 2009 | 2001 Pontiac Grand Am SE
Shifter is stuck in park
Billettechnologies.com sells a replacement cog to put your shifter backinto action. Their part replaces a factory plastic piece...no wonderthese are failing at a fast rate.
Here is the LINK to make this change out of parts...
Sep 22, 2009 | 2005 Dodge Magnum
3rd gear keeps jumping into 4th
Most likely the shifter cable just needs a small adjustment. First thing to do is to SLOWLY (while you are riding) tighten the barrel connecter at the top of the cable (usually where the cable comes out of the shifter and goes into the frame cable stay. Again make a small adjustment and it should correct. If this does not solve the problem try adjusting the rear deraileur high and low adjustment screws (just a 1/4 to 1/2 turn at a time to adjust.
Aug 27, 2009 | Cycling
Top derailleur not returning to first position
There are several possible problems with your deraileur. The first and most common reason for your derailleur not shiftering back down to the small chainring is a result of a cable and/or housing becoming contaminated or damaged. First check that the cable is not hanging up on something. Next look for any damage to the cable or housing starting at the shifter and working your way back to the derailleur. If the cable/housing is not damaged check to see if it looks rusted or just plan dirty. If any of the above is true it is recommended that you replace the cables or housing. If it is only slightly rusted or dirty looking you can try lubing the cables/housing with something like Tri-Flow. This may get the cable moving again take care of the derailleur problem.
The next most common problem is the result of the derailleur itself needing to be lubed because it is contaminated. It is best to spray the derailleur with GT-85 and work the derailleur back and forth manually until it is moving freely. Make sure you have the shifter shifter into 1st gear so it can move when you begin working on it.
These are the two most commong problems with a front derailleur not shifting back down unless the derailleur has been damaged in a crash or adjusted incorrectly. I gather that the derailleur was working and then it stopped so it is not the result of damage or incorrect adjustment.
If you need any more advise or help with the cable installation process you can contact me at [email protected].
Hope this helps. Thank you
Jul 15, 2009 | Shimano Deore LX Mountain Bike Front...
I have an older Huffy, with grip shifters. The shifter (left hand) is almost impossible to shift the chain from the small sprocket to the middle or largest sprocket. The deraileur seams to be moving freely...
First, try to isolate the trouble like you have... obviously the derailieur is moviong freely. Next, I would disconnect the shifter cable from the derailieur (make sure to mark previous position of cable) Next, shift the left hand grip to see if the grip moves freely, you've already replaced the cable, soooooo, disassemble the grip and grease or replace the grip shift unit...hope this helps
Jul 13, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
On my bike with shimano ultegra shifters and 105 front deraileur, I can't shift onto the big chainring. The deraileur is not at the stop, but I can't move it any farther. How do I fix that.
Try this first:
Shift into the little ring and release the cable. Pull it tight (with pliers) and re-tighten the cable. It should shift now. If it doesn't, the solution is a little time consuming, so i apologize in advance.
First, flip your bike onto the bars and saddle. Now shift into the small chainring and your lowest cassette cog (the largest in number of teeth). Release the cable from the front derailleur and set the adjustment knob for the front derailleur to its center point. You should find it on your down tube. Now adjust the "L" setting on the derailleur while turning the crank so that its stop sets it in a position where it just skims the chain but does not touch it. Now pull the cable taut and re-clamp the cable. Shift into the middle ring and shift the rear derailleur to its highest and lowest gears, making sure the chain does not rub the front derailleur. If it does rub (it will be in either the lowest or highest cog on the cassette), adjust the front derailleur by way of the adjustment knob to clear the rub. Then shift into the big ring and you should have no problem. Set the "H" stop if necessary.
Jun 23, 2009 | Shimano 105 Triple Braze On Front...
Need to adjust the front derailer, it won't change gears
There are two small screws which control the travel limits for derailer systems. Normally located top left of front mechanism when viewed from side. Adjust to allow travel within limits of gearing. Make sure that cable is not slack when in low gear position.
Jun 10, 2009 | Mongoose Exile 26 Men's Full-Suspension...
GRIP SHIFTERS WILL NOT TWIST WHILE TRYING TO SHIFT
This is likely because either a) the cable leading from the shifter to the part you are pulling is seized or b) the shifter itself is seized or c) both are seized. You would have to undo the cable from the rear deraileur, pull the inside cable out from the casing from top to bottom. Check it and see if it is rusted or full of crud. Give it a cleaning and spray some light lube down the outer (black) cables, then reinsert the cable. While the cable is undone, it wouldn't hurt to see if you can twist the grip shifters. If they are still tight, then get some lube in the grip shift. Also make sure the rubber grips are not too tight against the shifter. Hope that helps...
Mar 23, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
2005 Mustang Automatic Shifter
The solution is that you must purchase the complete shift housing because it is all one piece and you can't just replace part of it.The dealer told me this is about $250.00 U.S. and it can be replaced by an intermediate skilled tinkerer. For right now I just live with the inconvenience as I can pretty much guess what gear Im in.
Sep 17, 2008 | 2005 Ford Mustang
GMC Denali 700C Road Bike Logo
188 people viewed this question
Top GMC Cycling Experts
Mike
Arnie Burke
Arnie Burke
Dennis
Dennis
Are you a GMC Cycling Expert? Answer questions, earn points and help others
