Hiya, Ive just replaced the heat and pressure rollers in a 7020 copier, (used to work in the industry and lost my manual/notes) its coming up with 34-1 which I thought was go into 25mode reset bit 3-1 to off, now its coming up with f34-1 and f34-4 Ive rechecked the thermistor there was a tweak to ensure the left hand one wasnt rubbing onthe new roller, and the right pair of sensors look clean but now its not going away, would that suggest the left one is faulty? Havent replaced the right pair yet although I do have a set. Any ideas?
Thanks Steve
Comments:
Jun 10, 2008
- replaced with the yellow wired product madly searching thru old boxes trying to find my old error code book for a f35-10 now, anyhelp on this would be appreciated, although I did find my parts disk but that didnt have error codes :(
Jun 12, 2008
- ive replaced with the yellow wired ones now getting f-35-10 error anyone got a code book handy? still cant fin dmine they are up in storage :(
thanks, Ill replace them and advise how it goes, pretty sure tehy were whte ones from memory. Cheers
Solution #2
posted on Jun 09, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If your pair of thermistors has white wiring instead of yellow (improved), replace the set with the latest part number, 26NA88013. The "left" one, is called a "thermostat", but is really a safety fuse. It should read dead short.
canon m32043 microfiche reader and printer 90 has just stopped printing. It starts but then seems to...
(More)
canon m32043 microfiche reader and printer 90 has just stopped printing. It starts but then seems to jam - I am sure it not a paper jam as the code doesnt come up. Any ideas
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is...
(More)
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is narrower, thus its dimensions are not constant.
Among the solutions I have resorted to were:
- ITB (which I cleaned);
- changed the reader unit afterwards;
- checked the mechaism responsible for the drums unit rotation.
None of the above solutions worked.
I would be extremely grateful for any hint or advice.
