Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Sears 17.5hp rider with new gas, plug, gas fliter, oil will not start. Engine turns over fine and every five seconds you hear a pop or gas exploding in cylinder but ther mower doesn't start
  • 110 Answers
Might be a broken keyway keeping the flywheel in time with the crank shaft. have to pull the flywheel off the top of the engine to check it. The keyway is like a timing belt or chain on a car engine. Do not put any lube on the flywheel or crankshaft when putting it back.
Posted on Oct 24, 2010
SOURCE:
Recently changed the oil for my 04 silverado, but the change engine oil warning will not go off, how do i correct this
After changing the oil and filter, reset the monitor by proceeding as follows:
Turn ignition On, but do not start engine.
Fully depress and release accelerator pedal three times within five seconds.
If CHANGE ENGINE OIL lamp flashes for five seconds, this indicates system has reset.
Start engine. OIL LIFE should change to 100%.
If CHANGE OIL SOON lamp lights again, repeat reset procedure.
2001-08 Silverado, w/Driver Information Center
Press MODE button until DIC (Driver Information Center) reads OIL LIFE LEFT/HOLD SET TO RESET.
Press and hold SET button until 100 percent is displayed. You will hear 3 chimes and CHANGE ENGINE OIL SOON message will go off.
Turn ignition Of
how to reset oil life on 2004 chevy silverado
Nov 10, 2016 | Cars & Trucks
Engine management light on car runs fine
Service engine soon or check engine light? Engine light needs scanned for codes. Service engine soon is for oil changes and such. To get rid of service lights, turn the key on, press the gas pedal three times within five seconds. The light will flash. turn the key off. it's reset. At least check or change the oil and filter though.
May 30, 2015 | Cars & Trucks
92 bmw 318 is runs good for 15 mins then it will start missin and engine lights on.i smell like oil smoke and i turn car off. what could it be ,could it be valve stem seals or what.
You smell burning oil. See if there is oil in your spark plug wells or down the exhaust side of the engine. If there is, replace the valve cover gasket. That may be related to the miss if there is a lot of oil on the plugs.
You say the (Check) Engine light is on. Your engine light will flash a code to indicate the problem if you turn the key to the On (just before it starts) and press the gas pedal all the way to the floor five times within five seconds.
http://www.pelicanparts.com/bmw/techarticles/Mult-Code_Reading/Mult-Code_Reading.htm
Mar 05, 2011 | 1996 BMW 318
How do I reset the change oil soon message in my 1998 Chevy Lumina after changing the oil?
This is done by turning the key on engine off and fully pressing the gas pedal to the floor sloowly three times within 5 seconds, the light will blink and go off then turn the key off for 3 sec and start engine, light should be off if not repeat steps. hope this helps.
Oct 27, 2010 | 1999 Chevrolet Lumina
I have a 1997 2.5 jeep wrangler.when you first start the engine it runs and sounds fine, then after about 20 seconds it begins to have a knocking sound only at idle. when you press the gas you cant hear...
It may be piston slap. This is caused by either engine wear with the piston bores being too large for the pistons, or by poor manufacturing tolerances, or a combination of both.
To test for this, start the engine up first thing in the morning and run it for about thirty seconds while you listen carefully and memorise the sound and intensity. Turn the engine off quickly, remove the spark plugs and put two squirts of motor oil into each cylinder. Reinstall the plugs, start the engine up again and listen. If you have piston slap the noise will have been greatly reduced or even eliminated for about thirty seconds seconds and then returns.
The fix is to rebuild or replace the engine, but if it works just fine then don't worry. Many slappy engines keep going for tens of thousands more mile. The fact that your knocking is only at idle suggests your crankshaft is not to blame.
Sep 26, 2010 | 1997 Jeep Wrangler
2003 HD Low Rider. Went to crank and gas+oil
sounds like stuck needle valve if it's carbureted,letting the gas run into the engine filling it up,has to go somewhere if its full,you need to drain it out,don't try to start it,with all that gas in the oil it will not get proper lubrication resulting in engine damage.Shut off the fuel valve or it will continue to run into the engine.Hope this helps
Apr 05, 2010 | 2000 Harley Davidson FXDL Dyna Low Rider
2000 volvo s80 ran out of gas put gas in but it wont start
Turn the key to full power (but do not crank the engine). You may hear a high pitched whine from behind you - that's the fuel pump running. Leave the key on for about five seconds, then turn it off for a minute. Turn the key on again for another five seconds, and off for a minute. Then turn the key on for five seconds, and then crank the engine.
If your car ran out of gas, you need to run the fuel pump this way to get fuel up to the engine again - all the lines from the tank to the engine are empty, so the pump needs to run to fill them.
If this doesn't work, it's possible that the fuel pump is vapor-locked and will have to be replaced. Some cars are more susceptible than others to this type of failure.
Dec 05, 2009 | 1999 Volvo S80
Stalls, with oil runing out the exhaust
you have a valve that is stuck in the open position head will need to be removed
then spray valves with wd40 and turn engine over a few times watching to see both valves open and closing,once that is working install head with new head gasket.this is caused by not properly storing the unit. gas should be drained at the end of every season and then ran to burn all gas off from carb and fuel lines once it quits remove sparkplug shoot a tablespoon worth of oil in the cylinder crank engine over for 10-15 seconds to distribute oil on cylinder walls and valves then re install plug now your unit is winterized ready for the next season
Jun 29, 2009 | Garden
Service engine soon light on in 2004 buick rendevous after accident. no codes given. turns on when engine starts.ran scanner- no codes... had to reset everything after car repairs. told not related to...
oh thats the change oil light expect it every 3500 to 4500 miles they glow.. you can usually reset it by holding down the trip button with the car off and then turn the key to the II position where everything lights up
so read me >>>>>
Buick Rainier 2004-06, Buick Rendezvous 2002-05 w/o (DIC) Driver Information Center
Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three time in five seconds. If the CHANGE OIL SOON’ indicator flashes two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on for five seconds, repeat the procedure.
Buick Rainier 2004-05 wI (DIC) Driver Information Center
The DIC display is located on the instrument panel cluster above the steering wheel. The DIG buttons are located on the steering wheel. Press button with the gas pump symbol to display engine oil life. Press button with the arrow symbol to reset engine oil life display.
Buick Rendezvous 2002-06 wI (DIC) Driver Information Center
To reset Service Reminder Indicator, turn ignition on with engine not running. Press the MODE button until DIC reads oil life left hold SET to reset. Press and hold the SET button until 100% is displayed. You will hear three chimes and the change oil message will go out. If the CHANGE ENGINE OIL’ message comes back on when the vehicle is started, the engine oil life system has not reset. Repeat the procedure.
May 08, 2009 | 2004 Buick Rendezvous
Code for reseting the Change Engine Oil Light
You don't need a code. Turn the key to the "run" position, depress the gas pedal fully within five seconds, either turn off ignition or start the vehicle. The light should flashh a couple of times and then go out. I hope this helps.
Dec 02, 2008 | 2001 Chevrolet Silverado 1500
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
103 people viewed this question
Top Craftsman Garden Experts
john h
lnbn1975
Sheldon Dedek
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
