I have a black box ! like an additional screen which I can't get off the screen?
  • 11,361 Answers
SOURCE:
Screen goes black after making call which means I can't punch in extension
Sounds like the proximity sensor. The phone has a sensor that attempts to determine if the phone is up to your ear, and then shuts the screen when it is to save battery. However, if you have a screen protector of any sort it can block the sensor, making the phone think it is up to your ear once you place the call.
Easiest way to test this is to disable the proximity sensor then place a call. If the screen does not instantly go black after you place the call, then you know for sure something is blocking it. If you have a screen protector, try removing that.
To disable the sensor:
  1. Goto settings
  2. Call settings
  3. Additional settings
  4. Uncheck the proximity sensor box
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_d13aca62d29ed9ae
Feb 22, 2016 | Android LG Optimus Dynamic II LG39C...
We have an NEC Plasma 60xp10 tv and NEC RU-M111 remote controller. we accidentally hit the pip button and now we can't get it to turn off. a black small box randomly pots on and off.
The black box is likely in the CC area labeled TEXT and can come from the set or a box connected for signal.
The other issue sounds like PIP or picture in picture is engaged.
Both issues may require the original remote to turn them off.
Dec 15, 2012 | NEC PlasmaSync 60XP10 60 in. TV
Printer stuck on LEXMARK screen. Lexmark Pro905.
Try to re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
If that doesn't help, I would suggest you to contact Lexmark Technical Support Center for additional assistance.
Nov 18, 2011 | Lexmark Platinum Pro905 multifunction...
Where's he fuse boxes for '97 Mercedes c230
Under the hood rectangle black box near the heater valves, between the suspension top mount and the front screen. There are some additional ones near the battery in the trunk.
Mar 27, 2011 | 2007 Mercedes-Benz C230 Sedan
Black box on screen
That sounds like a text box. Press the cc button and keep pressing it. You will see different closed captions options on your screen each time you press the button. Finally when it says cc off stop pressing the button and you should no longer get the black box. If you have a cable box connected you may also have to disable the captioning on it.
Feb 12, 2010 | Sharp LC-19SB14U 19 in. LCD TV
JVC TV has a black box on TV after watching a DVD. Tv picture is available around black box and have sound. But I can't see the TV shows with this giant black box in the middle. It happened after viewing a...
That black box is the closed caption display. There is a button on your TV remote marked cc, ccd, or closed caption display. When you press this button, you should see something pop-up on the TV screen. With most TVs every time you press the button the TV will cycle to the next cc option. There are several cc options available. One of the options should be "Off". Keep pressing the button until you see off and then stop. This should correct your problem.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 13, 2009 | Televison & Video
Blacked out box on lower half of screen
Hi, sounds like your closed captioning is turned on, go into the menu and look for "CC" or "text" and turn them off, video-tek
Feb 04, 2009 | Proscan PS50700 50" Rear Projection...
Tv Problems
Go into your customer menu to closed caption and turn off the "text" mode... What you're seeing is a text box from closed caption but unless you have that additional service it will just me a black square...
Bill
Dec 09, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Ekse
