Question about Bosch 23 in. SHU 8805 Built-in Dishwasher
I have a Bosch dishwasher, stainless steel front- with buttons on the inside top( same as display, and the washing cycle won't start. Water seems to be running into the washer, as I can hear it, but the cycle never starts. Recently, I had clogged garbage disposer issue that has been resolved. The dish washer drains into the disposer, and I had free standing water left behind in the washer for 2days during this time.. Could this be the issue? Can you help me figure out this problem? Thanks!!
SOURCE:
SOURCE: Bosch dishwasher
We were told by Bosch to not use lemon scent. Use the original generic soap with NO sprakle or smell because the jet dry does the rest. Just let the soap be soap. Hopes this helps.
Posted on Feb 20, 2008
odiebugs
  • 949 Answers
SOURCE: bad odor when open door after cycle
This is just a suggestion, run a cycle and after a few mins of it washing, open the door and add a cup of bleach and let the washer run. See if this helps.
Posted on Apr 09, 2009
buffalonyman
  • 1865 Answers
SOURCE: mold grows on dishes in bosch dishwasher
Put a bowl filled with 2 cups of clorox on the lower rack and run a wash cycle (nothing else in the machine) this will kill the mold spores in the machine, and clear the smell.
Posted on Jul 29, 2009
  • 91 Answers
SOURCE: How to get rid of rust on the inside of a Stainless steel dishwas
use a scotchbrite pad , or a scouring pad with soapy warm water
Posted on Sep 06, 2009
  • 250 Answers
SOURCE: bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Posted on Feb 21, 2010
Testimonial: "We ended up getting a Bosch repairman to come out. No fix we tried worked. Several parts replaced."
Why water won't drain when cancel drain wash buttons are pressed
Nice unit. Bosch is on top of the world when it comes to beautiful DWs.
Try to find answers on the Bosch help page or better yet the units manual.
Dec 13, 2013 | Bosch 24 in. SHY56A05 Stainless Steel...
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
I need to know what the buttons say on the dishwasher. Mine have no letters
Some SHX46 washers have 4 wash cycle buttons and others have 5. The button on the left side on top of the door is the start/stop button regardless of how many wash cycle buttons you have.
If you have 5 cycle buttons, reading from left to right they will be as follows.
1. Top Rack Only / Sanitize
2. Power Scrub Plus - (Long wash for heavy soil)
3. Regular Wash - (Economy wash for light to medium soil)
4. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
5. Rinse & Hold.
These buttons are also used for cancelling a wash cycle. Hold down buttons 2 and 4 (Power Scrub Plus and Delicate) at the same time to cancel a wash cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration - from left to right - will be:
1. Power Scrub Plus - (Long wash for heavy soil)
2. Regular Wash - (Economy wash for light to medium soil)
3. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
4. Rinse & Hold.
With this button configuration, the cancel cycle buttons are 1 and 3.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Dec 12, 2010 | Bosch 24 in. SHX46B05 Stainless Steel...
Dishwasher will not start. Several cycle buttons
check carefully on display buttons 2 buttons are marked reset push these together as you turn mchine on this should clear error if not you may have control pcb fault will need service tech.
May 26, 2010 | Bosch 24 in. SHY66C05 Stainless Steel...
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
THe dishwasher will not start.
what cycles does your dishwasher offer? there is a cancel reset. its usually holding scrub and econo wash at the same time while the power is on will activate the cancel drain mode then reset the dishwasher next time you power it. if that doesnt help then let me know your full model number and i will tell you exactly which buttons to press.
your model should read:
SHU66C05UC/??
what numbers are ??
Mar 03, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch SHY56A Dishwasher
if the door doesn't shut, the push buttons should not work. that way you are not running your d/w with the door open. check the door latch, as it seems to be malfunctioning. if the d/w still does not work, replace the door latch.
Aug 15, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 23 in. SHU 8805 Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
