Question about VeriFone VX510
My veriphone 510 le is casusing me enourmous problems getting a lost carrier, communication error and no host. have what is supposedly a anologue line plugged into a cable box it shares a spliter with my fax line sometimes i just plug directly into my box cant run any cards for the past 2 days what should i do
2 Suggested Answers
SOURCE:
  • 113 Answers
SOURCE: Veriphone VX510 LE has trouble on noisy dial up
the unit probably has a bad crystal and need to be replace it or maybe is not PCI complaint in the unit need to go to the main program to find out if the unit is pci complaint go 1 alpha alpha 66831 scroll to the system info look @ the part number and compare to the pci complaint chart if don't know how, we can help you just call us @ (775) 358-2922
Posted on Nov 21, 2011
My cellphone is lost need a blacklisting number?
Telefondinleme7.com CASUS TELEFON D?NLEME, TELEFON TAKIP PROGRAMI, casus programlari ile casus yazilim, dinleme cihazlari
Cep telefon takip programi, casus Whatsap takip yaz?l?m? Kullanima hazir casus telefon programlari ile kullanimahazir telefon takip, telefon takip sitesi, telefon takip sistemleri, akilli telefon takip programi, Casus cep telefon dinleme cihazi yazilimi ve programi, Cep telefonu nasil dinlenir, Casus yazilim, Telefon dinleme, telefon dinlemesi, telefon dinlemek, telefon dinleme cihazlari, telefon dinleme uygulamasi, bilgisayardan telefon dinleme, Casus program, Android Casus telefon dinleme programi, akilli telefon dinleme programi, cep telefonu dinleme programi, en iyi en ucuz telefon dinleme programi, telefon takip cihazi, telefon takip izleme, Akilli telefon dinleme, telefon dinleme cihazi, telefon dinleme programi, telefon dinleme yazilimi, android telefon dinleme, cep telefonu dinleme, bilgisayardan telefon takip etmek,
iletisim
0 850 840 5 211
0 232 332 0 325
0 212 909 1 438
[email protected]
http://www.telefondinleme7.com
casus telefon
telefon dinleme
May 03, 2016 | Cell Phones
What is communication error 20 mean ?
The Comm. Error message may appear if the machine experienced a communication error while sending or receiving a message. This type of error is generally caused by interference on the telephone line, an incorrect telephone line connection, or an alarm system or other device on the line. In your case, it lost connection to the host / server. You just need to keep retrying or check the settings on the phone and confirm with the vendor if they have changed some settings on their end...such as PORT #, etc...
Sep 02, 2015 | Computers & Internet
Can a VeriFone vx510 be wired into a dedicated phone line,process say a sale than let the line become active again so you can use said phone?
the terminal requires a dedicated analog phone line. it will allow you to use the phone while you are not using the terminal. if you are in the process of running a transaction and the phone rings or someone picks up the line you can get communication errors and will have to try to reconnect the communication so the sale can be processed.
it does work though but it causes some issues at times
Feb 14, 2015 | VeriFone M25100033NAB Vx 510 Countertop...
Veriphone "Bad mac"
is your verifone you are talking about is a pinpad 1000se or the creditcard machine (VX510, VX570 etc.) and bad MAC (message authentication code) and i believe if the machine is not encrypted right or the encryption was errased for some reason, bad mac will appear. I've seen some of bad mac error together with tamper error on VerifonePinpad because the battery is going bad. Replaced battery and load the encryption, pinpad works again. Hope this will help you or call (775)358-2922 look for randy and maybe we can help you further. thanks
Nov 01, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
Spinning Motor is overloading
Hi
Thanks for using FixYa. LE error is a communication error between the control board and the motor. In you LG washer the Hall Effect sensor board monitors the direction and speed of the motor and sends this information to the control board. Usually the issue is with this Hall Effect sensor going bad and should be replaced. However, to make sure it’s not a locked motor, try turning the drum with your hand. And, if you feel some resistance while turning the drum or the drum doesn’t move freely then the motor is locked and you’ll need to get it replaced. If it is fine then it is the Sensor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | LG WM-2277HW Front Load Washer
Will a veriphone 3750 work with Digital phone service? I keep getting a no dial tone error.
No, sorry, you will have communication problems on any digital or VOIP (voice over internet phone) lines. Analog phone providers is the only phone system that will take care of this problem.
Oct 20, 2009 | VeriFone Omni 3700
Carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
Jul 07, 2009 | Heating & Cooling
Whats the problem when my phone says communication host not found
The phone is attempted to contact a Project Server and was unable to make the connection because the Host (server) was not found. The Host Name did get converted into an IP Address, but the Host itself could not be located. Often these messages are indicative of a temporary failure, particular if the host / device was functioning properly and no changes were made, at all, and the internet connection otherwise functions properly.
You may need to contact the phone carrier or the manufacturer for second opinion.
Have a great day!
May 14, 2009 | LG Shine CU720 Cellular Phone
Intermittent error code E713-0004 Already replaced every board in copier and finiser (R-1). Also replaced the wire harness from copier to finisher, even tried another R-1 finisher, still throws code.
E713-0004 -05 Title Finisher IPC communication error (checksum error)
Remedy 1. Check the cable connection of the Finisher.
DC Controller side: J462, Finisher Lattice side: J9043
2. Replace the Finisher Controller PCB.
Description Communication between the host machine and the Finisher was lost
Dec 18, 2008 | Canon Office Equipment & Supplies
VeriFone VX510 Logo
138 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Marvin
Marvin
mclaen
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
