Question about Kodak EasyShare Z7590 Digital Camera
Software Upgrade I received a notification to upgrade my EasyShare Software. I selected the upgrade and near the end of the upgrade I received a message stating something about the Windows logo not be correct. Now I cannot download any photos from my camera. I removed EasyShare Software and tried reinstalling. It still does not work. Please tell me how to correct the problem. Thanks!
    President:
  • 2,712 Answers
This error message indicates that the drivers are not digitally signed by Microsoft. In the event that you receive the error message referenced above, please continue with the install. Despite the fact that these particular drivers have not received the digital signature from Microsoft, they will work on Windows XP.
If you have difficulty installing the software from a direct update through the web, download the file first to your PC and then run it from there, if possible. Should you still have difficulties, try a clean boot of the camera software as explained here:
http://www.fixya.com/support/r545614-installation_problems_clean_boot_install
Hope that helps. Kindly take a moment to rate this solution a Fixya if you found it helpful. thanks.
Posted on Jun 08, 2008
My C 743 does not see the SD card.The card is good and is used in another C 743. Have I messed up a menu setting or is this a camera problem?
the kodak C743 can only take upto 8gb SDHC card , if you have a 16 / 32 / 64 & 128gb card these will not work
try upgrading the firmware from the website by this method
  1. Visit the EASYSHARE Software page and download the latest version of software.
  2. Connect the camera to your computer using a USB cable.
    NOTE: The first time you connect your camera to your computer, Sync and Transfer Setup or Sync and Transfer Assistant prompts appear on the screen. Follow the prompts to set up the camera as a device in the software.
  3. Remove the memory card from the camera.
  4. Turn on the camera.
  5. Start EASYSHARE Software.
  6. Select Tools > Sync and Transfer Manager.
  7. Select your device from the list in the left column, and then select the Info tab.
  8. Click Update Firmware, and go to the location where you downloaded the firmware file.
  9. Click Open to copy the file from your computer to the internal memory on the camera.
  10. Turn off the camera, and then disconnect the USB cable from the camera.
  11. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes. When it is complete, the camera will delete the firmware file from internal memory.
  12. Turn off the camera, and then turn it back on again.
good luck
Apr 01, 2011 | Kodak Cameras
I have a Easy Share C530 and I have Visa the two programs are not working together
You need to upgrade your version to be compatible with Windows Vista: Please do a Clean Install on the software:
Please follow the instructions:
  1. Uninstall Easy Share software:
  2. Select Start > Settings > Control Panel > Add / Remove Programs.
    For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
  3. Select Kodak Easy Share software.
  4. Select Remove (or select Change, and then select Remove).
  5. Run the Clear utility:
  6. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
  7. Click the Download button, and then follow the on-screen prompts.
  8. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Dec 21, 2009 | Kodak EasyShare One Digital Camera
Picture file size too big when loaded into easyshare software
Upgrade you computer.
You could also lower the quality of the pics on the camera.
Menu, Camera Settings. Pixel Quality.
Nov 22, 2009 | Kodak EasyShare DX7440 Digital Camera
Lost kodak easyshare in computer during upgrade
The best solution for this problem is to go to Kodak.com and download/install the current version of the Easyshare software.
Oct 24, 2009 | Kodak EasyShare C613 Digital Camera
Kodak easy share C813, the display is over saturated
Using exposure compensation to adjust picture brightness Before you take a picture, you can adjust exposure compensation to make pictures darker or lighter.
The exposure compensation level is shown on the LCD; the LCD gets brighter or dimmer.
OR
You need to upgrade the firmware.
Download this file to your pc and follow the instructions:
Firmware Download
Installation Instructions IMPORTANT: Print this page before continuing.
Prepare your Camera CAUTION: Loss of power during the firmware upgrade can render your camera inoperable.
  1. Connect the optional KODAK AC Adapter, or install a new or fully charged battery in the camera.
  2. If you have pictures on the internal memory of your camera or on a memory card, save the pictures to your computer.
Download and Extract the Firmware File
  1. Download the file to your computer.
  2. Double-click the file to start the WinZip Self-Extractor.
  3. Select Unzip to folder, and specify a location, or leave the default location.
  4. Click Unzip. The firmware file unzips to the specified folder.
  5. Note the location of the folder. The file has a .fw file extension.
  6. Close the WinZip Self-Extractor.
Select a Method
  • If you do not have a memory card and card reader, use Method 1.
  • If you have a memory card and a card reader, use Method 1 or Method 2.
Method 1
  1. Visit the EASYSHARE Software Web page at www.kodak.com/go/easysharesw, and download the latest version of software.NOTE: EASYSHARE Software version 6.x or later must be used during this procedure.
  2. Remove the memory card from the camera.
  3. Turn on the camera.
  4. Format the internal memory of the camera:
    1. Press the menu button.
    2. Select Setup.
    3. Select Format.
    4. Select Internal Memory.
    5. Press OK.
    6. Press OK to continue.
  5. Connect the camera to your computer using a USB cable.NOTE:The first time you connect your camera to your computer, Sync andTransfer Setup or Sync and Transfer Assistant prompts appear on thescreen. Follow the prompts to set up the camera as a device in thesoftware.
  6. Start EASYSHARE Software.
  7. Select Tools > Sync and Transfer Manager.
  8. Select your device from the list in the left column, and then select the Info tab.
  9. Click Update Firmware, and go to the location where you downloaded the firmware file.
  10. Click Open to copy the file from your computer to the internal memory on the camera.
  11. Turn off the camera, and then disconnect the USB cable from the camera.
  12. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes. When it is complete, the camera will delete the firmware file from internal memory.
  13. Turn off the camera, and then turn it back on again.
Method 2
  1. Remove the files from the memory card.
  2. Place the memory card in the card reader.
  3. Open the drive corresponding to the memory card to view the card contents.
  4. Check that a System folder exists on the memory card. If not, create one.
  5. Locate the firmware file on your computer and copy it into the System folder on the memory card.
  6. Remove the memory card from the card reader, and insert the memory card into the camera.
  7. Turn off the camera.
  8. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes.
  9. Turn off the camera, and then turn it back on again.
Sep 10, 2009 | Kodak Easyshare C813 Digital Camera
Kodak easyshare software error 1624x17x4252799284x
You need to run the clear utility before installing the software www.kodak.com/go/clear, then download the latest version at www.kodak.com/go/edl
Jun 10, 2009 | Kodak EasyShare One Digital Camera
Upgarding kodak easyshare software keep coming back with error
check your computer specification.. check if your computer meets the requirement for new easyshare updates or easyshare versions.. you can check the required computer specification on the download page of the easyshare.. i have easyshare at home and i check the requirements for the software, no problem with the upgrade.. check also your security settings, sometimes the security on the computer does not allow you to do the update..
Will I loose photos or captions when upgrading EASYSHARE SOFTWARE
First of all.
You should always backup your data onto CD/DVD/memory stick or other external device !
And that does include photos.
You will not loose any data when you upgrade.
My personal opion is:
Download "Picasa 3" (free from google)
It is the best free program for non pros.
You can then import all your saved photos
Feb 24, 2009 | Kodak EasyShare C613 Digital Camera
Installation and Usage Tips for the DiMAGE 7 Optional Enhancement Upgrade:
Taken from the DiMAGE 7 Upgrade Software Installation Pamphlet… Power Supply during Update: When performing the software update, please use a set of fully charged NI-MH (nickel hydrogen) batteries or the AC Adapter AC-1L or AC-2L (sold separately). When using the AC Adapter, be sure not to inadvertently disconnect the camera during the software updating procedure, otherwise the camera may be permanently damaged. Amendment to the DiMAGE 7 Upgrade Software manual… (Located on an insertion card within Upgrade Kit and Upgrade Firmware boxes) For Windows XP users: Do not copy the dsc.app and ram.bin files directly from the CD-ROM to the CF card or the upgrade will not be executed correctly. First copy these two files onto the computer’s hard drive or desktop, and then copy them into the CF card. After upgrading: When the camera is turned to the playback mode, the no-image message appears and the images taken before the upgrade are not displayed. These images were placed in a folder with names ending in MLT03, the upgraded camera places images in folders ending in MLT14, see CompactFlash card folder organization in the DiMAGE 7 manual. To view images taken before the upgrade, select the appropriate folder in the custom 1 section of the setup menu. Refer to DiMAGE 7 manual for a description of this function. When using autofocus with the wide focus frame, the live image may freeze for an instant as the AF system determines the focus. This is because autofocus speed is increased
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Software drivers
A driver is a piece of software used by your computer to communicate with a particular peripheral, like your camera or scanner. If your driver isn't updated or properly installed, it may stop your camera from communicating with your PC. This could lead to an abundance of error messages. Drivers are regularly updated, and new versions can help fix problems and bring a significant improvement in performance. There are two main reasons to upgrade drivers. Incompatibility is the most frequent problem solved by a new driver release. And new drivers optimize the communication speed and task sharing between a processor and a peripheral. A new driver can increase performance as much as 50 percent. You can sign up to receive notifications of driver updates from HP.
Sep 08, 2005 | HP Photosmart 945 Digital Camera
Kodak EasyShare Z7590 Digital Camera Logo
106 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
