Computers & Internet Logo
Posted on Oct 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I enter http://192.168.10.1 for the log in page for Trendnet, it does not come up. I cannot get to the initial log in page for Trendnet.
Anonymous
Level 3:
  • Master 1,768 Answers
  • Posted on Oct 25, 2010
Anonymous
Master
Level 3:
Answers
1768
Questions
0
Helped
528655
Points
5915
You are possibly not using the correct information to log into the router.
Please verify your hardware and TCP/IP settings again by following the instructions in sections 2-3, make sure the Power, Wan, WLAN,and the LAN lights on the AP/Router's front panel are on, and verify that TCP/IP configuration is correct. Then, try accessing 192.168.1.1 again using the web browser.
How do I set a static route lan side on a tew-733gr
You need to download the user guide from here
TRENDnet Support
Basically
1. Make the computer or network device (for which you are establishing a DMZ link) has a static IP address (or you can use the DHCP reservation feature to ensure the device has a fixed IP address) (see "Set up DHCP reservation" on page 29).
A. Signing up for a Dynamic DNS service (outlined in the DDNS section) will provide identification of the router's network from the Internet.
2. Log into your router management page (see "Access your router management page" on page 22).
3. Click on Access, and click on Firewall & DMZ.
4. Next to DMZ Enable, click Enabled.
5. Next to DMZ Host IP, enter the IP address you assigned to the computer or network device to expose to the Internet.
6. To save changes, click Save Settings.
How do I set up a secure password?
For trendnet
Your Trendnet wireless router lets you broadcast your home network across your entire house, so you can access the Internet in any room. This signal may be powerful enough to extend into neighbors' houses, where they could easily jump on the network if it is unsecured. To protect your network, set up Wireless Encryption Protocol, or WEP, to encrypt data and prevent access unless the user enters the correct password.
Type "http://192.168.0.1" in your Internet browser's address bar and press "Enter." Enter "admin" for the username and leave the password field blank. Click "Log In" to log into your Trendnet wireless router's administrative program. Click "Wireless" from the left pane of the "Basic" tab. Click "WEP" under the "Wireless Security Mode" section at the bottom of the screen. Enter your preferred password for the network. A strong password is made up of a random selection of numbers and letters. Click "Save Settings" at the top of the screen to save your WEP settings.
trendnet wireless router users guide
http://downloads.trendnet.com/tew-611brp/manual/ug_tew-611brp.pdf
Hi i have trendnet te100 s24 switch and i want to do some configurations on vlans but i do not known how to do that especial getting into the switch interface can you help on this.my regards to you
Usually all those switches are plug and play ..and do not need much configuration ..but if you want to make changes or you changed the way you connect to the main internet source ...you have to use the same computer that was used first for configuration ..(it will be seen as admin ) ..and the log to the settings will be made the same as for a router..Look on the back of the switch ..and see what IP address has from the factory ..and type the IP address into the browser and hit enter..
for example in internet explorer ..write on the address bar ..:
http://192.168.1.1
(this si just an example ..but the ip for the switch will be written on its sticker
it will take you to the log in page ..and in there if nothing was changed .. ..you have to complete the lines with the words admin ..and password..or with the ones you selected when you first configured it ..
In case you forgot all these..it should have a hidden button that will allow you to reset it ..and after that it will be to the factory defaults and will accept the IP on the sticker and the words specified in the manual for login ..to settings ..or ..will go to settings without the log on screen .
My TrendNet modem has the "System" light always
Hello
Your going to need to log into the modem/router.Check with manufacturer on how to log in.
Once logged in there should be a page, to turn wireless on.
Here is a link to your router user manual.
http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=1504
I am the owner of Trendnet TEW634GRU. I have a problem for installation. When I access to the web page http://192.168.10.1, the default admin: admin and the default password: admin doesn't work to log in....
make sure you have reset the router first.
It sounds like the password was changed (as it should be)
The reset will put it back to factory specs and you will start fresh with all the settings.
TRENDnet TE100-P11 shows print online but won't print
You have to create an LPR port for it to print successfully.
Download the User's Guide from the following link http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=1316
and then follow the instructions from Page 22 to 24
1helpful
How to reset the security key of my trendnet tew-430apb 54mbps wireless access point?
To change your router wireless security
  • Support site here http://www.trendnet.com/products/proddetail.asp?prod=150_TEW-430APB&cat=83
  • User guide here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10853
  • Quick setup here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10856
Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - Enter IP address http://192.168.1.100 to the address location. When there is a screen needs to enter the User name and Password, both of the default Username and Password is “admin”
Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password. See Page 12 of the User Manual
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7: http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=214 - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --
Wireless Profiles - XP http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=186 - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
3helpful
Manual Setup of Trendnet Router
1. Open Internet Explorer 5.0 or above Internet browser.
2. Enter IP address http://192.168.10.1 (the factory-default IP address setting) to
the URL web address location.
3. When the following dialog box appears, enter the user name and password to
login to the main configuration window, the default username and password is “admin”.
Top Trendware Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
