Question about Lenovo 3000 V100 Notebook
HL DT ST DVDRAM GMA 4082N ATA Dav5ce has registry corrupted Could you help me It does not work
The device manager gives a message "the register is corrupted"
The brand of my laptop is LENOVO. the same problem occurr with USB driver I can not install a external DVD RW.. The laptop has preinstalled Windows Vista Home Basic.. I got it a 3 yeas TELUS promotion. It is the 03 months and I can not use the DVD. Help me. Please.
  • Anonymous Aug 18, 2008
    Toshiba Satellite 2 yrs old with this dvd drive, fails to read any dvds...only will detect CDs:
    HL-DT-ST DVDRAM GMA-4082N ATA DEVICE
    There is no error message, nor warning in device manager. Says working.
    This seems very similar to thread fixya Toshiba/Matshita DVD drives. It used to work, then sometimes didnt (read dvd movie as both empty and full, would not play it), now it wont see the dvd disc at all. Light goes on in drive, some noise like its starting, then nothing.
    If I replace this drive, it will be the third such drive in a 2 yr old laptop. Upon buying it, DVD drive was defective, started to play movie, then shorted out laptop! Exchanged for completely new laptop at store. Is this a faulty DVD drive or some other problem? Reformatting laptop made no difference so I dont see how it can be drivers. Laptop running Vista.
    I also tried on my Mandriva 2007 Linux partition, which also could not read any dvd movie discs, and gave a message about 'g-streaming' missing or something like that.
  • 67 Answers
HI , This is problem is comming due to Your registry might be corrupted so -
loadTOCNode(2, 'resolution'); 1. Remove the Upperfilters and Lowerfilters values completely from the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}NOTE: If you are getting a code 39 message, it may be that additional third-party filter drivers were added to UpperFilters and LowerFilters values in addition to Adaptec filter drivers. In that case, you may try to remove the non-Adaptec filter drivers first, leaving the Easy Creator filters in place to see if the Code 39 goes away. If you still receive an error code 39, 32, or 31 message, remove the Upperfilters and Lowerfilters values completely in the preceding key.
2. Restart your computer.
Posted on Jun 20, 2008
HL-DT-ST DVDRAM GMA-4082N ATA DRIVER DEVICE Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) My cd/dvd drive stopped working. it says that the...
backup whatever information you have and run the system recovery through the disks you received when you purchased the computer. If you can perform the recovery then you know the hardware is fine and that you were experiencing software corruption.
Nov 16, 2009 | Toshiba Satellite A135 Notebook
GMA 4082n device driver not working properly code 39
The dvd does not need driver, you need to reinstall Windows.
Jul 18, 2008 | Toshiba Satellite A135 Notebook
HL-DT-ST DVDRAM GMA-4082N ATA DRIVE CODE 19 IT SEEMS THE REGISTRY IS CORRUPTED HOW CAN I REPAIR IT OR GET THE DRIVER
The driver can be downloaded from HP's website under Drivers and Support. Unfourtunatly corrupt registry entries are really hard to work with. I do not know any other way then to reinstall the software and hope for the best.
Good Luck
Jun 17, 2009 | Toshiba Satellite A135 Notebook
MY LAPTOP DOES NOT RECOGNIZE MY DVD/CD DRIVER... CODE 39
you need to do
1) confirm the dvd driver works ok at other same laptop or find a usb dvd drive adapter to check it works well or not, the dvd driver damage if not
2) check the dvd interface pins (no damage or disconnection) on the motherboard, there is hardware problem that you can not see or heard any lights and driving sounds when the power on
Feb 06, 2009 | Acer Aspire 5610-4648 Notebook
First go into Setup (usually F1,F2 or del) at start-up. See if your drives show up there. With Windows running, right click My Computer, left click Properties, left click Hardware, left click Device Manager, left click DVD/CD-ROM drives. Also check IDE ATA/ATAPI controllers. Do the drives show up there? If they do right click on drive and left click Update Driver. If they are not there go back to System Properties and left click on Add Hardware Wizard. This will search for devices. It may ask you to insert Windows CD which of course you can not do because the drives don't work. Try a different drive. When you cleaned out your computer did you delete or uninstall Office? That may be what caused this problem. None of this may work but it is a starting point.
Jan 06, 2009 | Dell Dimension 4600 PC Desktop
check whether the device is detecting properly on bios or not
Oct 01, 2008 | Computers & Internet
http://support.microsoft.com/kb/314060
Try this article...............hope it should work otherwise would suggest something lese as well......All the best....TC
Jul 20, 2008 | Toshiba Satellite P105-S6104 Notebook
Thank you for using Fixya.com and glad to hear to got your monies worth.
Regarrds,
Worldvet
Jun 08, 2008 | Toshiba Satellite P100 Notebook
Go back to the device in device manager, right click on it and select properties, then under the driver tab click on "Roll back driver" button and see if that does the trick.
May 07, 2008 | Toshiba Satellite P100 Notebook
sounds like your cd/dvd is mechanically shot. time for a new one.
Mar 09, 2008 | Lenovo 3000 C200 Notebook
Lenovo 3000 V100 Notebook Logo
1,148 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
