Question about GE JVM1330BW/WW Microwave Oven
Hi - Looking for mounting instructions for my microwave listed below - actually I'm trying to take it down so I can replace with a newer model - I removed the top screws, but it seems to be hanging on some kind of mount bolted to the wall...
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Oct 24, 2010
SOURCE:
How do I remove a GE microwave to replace it?
Look under it and in adjacent cupboards from mounting screws. Some just pull out.
Here are the installation instructions for a similar GE Microwave
http://www.homedepot.com/catalog/pdfimages/d4/d4de3943-f969-4aae-a358-21d0712ed1c7.pdf
Oct 11, 2016 | GE JVM1190 Microwave Oven
Door button not working need replacement; send me the instruction how to remove the old one and replace it with new one.
Try looking at this diagram and parts guide. Click on a picture to drill down to more information and parts list.
Word of caution! Inside the case of a microwave are lethal voltages that persist long after the unit is unplugged. Stay clear of the transformer, diode and capacitor. When in doubt, discharge the capacitor with a large resistor first (10,000 ohms). Do NOT short the cap directly - it can damage the cap and scare the crud out of you with the noise.
http://www.searspartsdirect.com/panasonic-microwave-parts/model-NNSD297SR/0789/0123370.html
May 21, 2015 | Panasonic NNSD297SR 1200 Watts Microwave...
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
I don't have a problem, just would like an estimate on how much I should try to sell it for. Thanks for your help.
I found references to one similar model, and it was circa 2000. Yours has many nice features, but the price of a microwave has come down since 2000. If you are looking to replace it with a newer model, I would suggest that $80 to $100 might be a bit much, but a good starting point. The one thing lacking in yours is sensor cooking, which some find desirable. Since the prices have fallen somewhat, it's actually hard to get what they're really worth, since you can buy a new one rather cheaply, compared to a few years ago.
Best regards, --W/D--
Mar 08, 2011 | Whirlpool MH6130XEB/Q Microwave Oven
Trying to change a fuse on microwave.
It may be the fuse or the thermal cutout / thermostat associated with the magnetron.
You say you have the service manual? If you mean the folded-up "mini-manual" that should show the relative locations of the parts in a perspective view.
Also, you can find exploded views at the Sears parts site.
Looking at the "interior parts ii" exploded view here, it shows the fuse (drawing reference # 5001) on the small RF noise filter board located on top of the air duct assembly.
You'll need to remove the oven from the wall to get to it for testing & replacement.
The installation instructions are handy to pull the oven from the wall.
If you've misplaced yours, the Sears site may have them free.
You can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they may ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
May 28, 2010 | Kenmore 80809 Microwave Oven
Where is fuse located in microwave
Yes but need the model number to help you know where it is.
Aug 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have an old sears sensor touch microwave oven model no 565.69580890. When I press the keys to start nothing happens -microwave does not start using the key pad at all ...but if I hold down the door open...
Well yes this Microwave Oven worth repairing, you need to change the control board of this oven cost approx. 125 usd.
post further comments for more help....
Good Luck!!
Thanks
Aug 21, 2009 | Kenmore 63792 Microwave Oven
Looking for Installation Instructions for microwave.
Yes to all of your questions. There is a mounting bracket which is specific to this model.
here are the installation instructions http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-InstallationInstructions.pdf
here is the owner manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-Manual.pdf
here is the witing diagram
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-WiringDiagram.pdf
and here is the parts manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-PartsManual.pdf
Download these manuals and you will have all of the info available on this microwave. Check to see what is missing and then get what you need by clicking on this page and the where to buy line
http://www.frigidaire.com/customersupport.aspx
enjoy your new microwave.
May 23, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
How can I install this oven GH9115XE?
You may be looking for this flat head 1/4 x 28 threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded holes in the top of the microwave:
GE # WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites)
or a set of three
GE # WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites)
Jan 21, 2008 | Whirlpool GH9115XE 850 Watts Convection /...
Microwave Ovens Logo
118 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
