Question about Samsung LN-S4092D 40 in. LCD HDTV
Weak or no signal message
My samsung lcd tv is giving me a weak or no signal message. it worked fine earlier no signal been trying for 10 hours to play with remote control and program under CHANNEL all versions without luck.
what shall i do?
  • 1 more comment
  • Anonymous Jun 30, 2008
    I don't have cable nor satellite. I did however purchase a new antenna (RCA) for my new HDTV LCD Samsung...32 inch home theater
    I continue to get weak or no signal intermittenly.
  • Anonymous Jul 01, 2008
    we are getting "weak or no signal" on our Samsung TV screen also??? no picture and no sound??
  • Anonymous Mar 21, 2014
    no signal
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Posted on Nov 18, 2008
I'm having the same problem. My tv has been working completely fine and now it just popped up a gray fuzzy screen and says Weak or No Signal. What do I do to get it to work?
Posted on Jul 30, 2008
  • david chaves Dec 22, 2012
    get a new signal board cause its goin and its the common problem with them
Try retuning it then reboot the tv and then enjoy worked for me
Posted on Jul 17, 2008
My samsung 3D led multisystem smart TV remote control does not work anymore
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
Suddenly dropped hdmi signal on all ports - sees device but gets
Switch off the TV, switch off power and remove plug and wait for 48 hours and retry.
Jul 28, 2012 | Samsung UN55C9000 55 in. 3D LCD TV
Hello, In the last couple of days my Sony TV (KDL32S3000) has been working fine for about 10 minutes then a message appears saying 'POWER WILL BE TURNED OFF BY AUTO SHUT OFF SOON' this message...
If this happening when TV is viewed then it is possible that the auto shut off is active as no signal is detected by the processor and so is instructing to shut down.
However this fault is related to a problem in the signal detection circuit, if this happens with the auxially circuit- play station- then some logic gate is faulty which needs to process and detect the signal.
Remove power for few hours and see if the fault resets, if not the circuit needs a technical review.
Jul 08, 2011 | Sony KDL-32S3000 32 in. LCD Television
I have two Samsung HD ready series LCD TVS in two different rooms. Both have their own Samsung remote. TV1 works fine. TV2 works fine BUT when TV@ remote switches TV2 on it also switches TV! off! How can...
Hi, To change one of your TV with another brand is not a wise decision indeed. Well, Your TV has a remote sensor in the front side. Try to places both TV on opposite position. Otherwise use the used batteries on both of your TV remote commander. This will reduce its signal.
Regards
Jan 17, 2011 | Samsung TV Remote Control
Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Jan 01, 2010 | Samsung LN32A330 32 in. LCD TV
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
"Weak or No Signal" message on Samsung 26" LCD TV
I pressed mute on my television and about 5 minutes later it said weak or no signal.What do I do?
Feb 24, 2009 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
Weak or no Signal issue when connected to my TV.
Yes weak signal. Also closing the laptop lid puts the computer in sleep mode.
Jul 07, 2017 | Digital Lifestyle FA1B32Z 32 in. LCD...
Is this a joke? How am i suppose to get help?
Dec 17, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung LN-S4092D 40 in. LCD HDTV Logo
14,244 people viewed this question
Henry  Thomas
Henry Thomas
