Question about JVC GM-V42 42 in. Plasma Television
Problem with my jvc av42pd20es picture looks like a negative photo
Hi i have just bought a plasma tv from an auction it was very cheep but has a problem when i switch it on the picture is very faint and it looks like a negative photo ,can it be fixed
  • kitcar kenny Jun 08, 2008
    thanks for the info jerry. i only paid 14 pound for it so i might sell it on that website best regards,kenny
  • pelagichunt Apr 20, 2009
    My JVC PD-42V475 does the same thing, it went from working perfectly to this after turning it off one night and back on the next day. (there was no lead up, it happened all at once). Additionally, it starts with black pixels several inches around the perimeter that gradually go away after it warms up for a few minutes.
There is a setting on the menu called colour reverse.
Check to see if that is left on. If it is, turn it off and it should be fine.
Posted on Feb 07, 2009
    Genius:
  • JVC Master
  • 1,689 Answers
There are two things that can cause what you see.
The main drive board to the Plasma tube is not supplying proper drive voltage, or proper biasing to the Plasma tube. Or, the Plasma tube itself have gone weak.
I hope you did not pay too much for that screen. This type of repair is very expensive! I am sure that is the reason why the seller put the set up on auction.
I always tell our customers, to never buy used unless you know the seller is reliable, and that you can test the set and have it professionaly checked before buying it.
If you can find a couple of Plasma sets of the same model with a good display tube and maybe some bad boards, you can then do some board swaps to make one out of the two. That is if the used sets you get don't all have the same fault. We've also been through this.
Jerry G.
Posted on Jun 08, 2008
Sharp 52" LCD-Negative picture
hi bring the menu up if it's the same as the picture, the mainboard could be the problem, also can be a bad panel thanks
shaun
Mar 04, 2017 | Televison & Video
I have a JVC I'Art Pro 42" HDTV ready projection TV. Recently, it started intermittently flickering (Picture would go from correct to negative looking). Now this video circuit problem is negative picture...
Hi.
It is not video circuits on main controller or convergence.
This TV uses a CRS system with three CRT tube lamps, red, green and blue.
The problem is likely one or more of the CRT individual high voltage PSUs failing intermittently, if problem is associated to vibration, then it is a cold solder joint , otherwise it is a faulty component.
Aug 20, 2010 | JVC Televison & Video
Hi, I just bought a new lcd tv and the picture is great when you look straight at it, but if you look at it from an angle it turns like a photo negative. Please help
Hi nothing you can do about that - sounds reminiscent of the old school LCD computer monitors/ laptop screens. the LCD technology has advanced significanty to170 degree viewing angles to all but eliminate this artefact.
Aug 10, 2010 | Televison & Video
Picture suddendly changed to "photo
hi! your lcd cpu is defective, here in the philippines we try to re heat the cpu and it works.
Sep 04, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Where can i get parts for my jvc television
go to www.sears.com parts dept have make and model ready!
This should fix ya!
Dec 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Zenith Z50PX20
It is quite possible the magnesium capacitor next to the continium transformer needs replacement.
Feb 28, 2008 | Zenith D52WLCD Television
JVC AV42PD20ES
I was able to create the same condition on my plasma tv by disconnecting the upper and lower y-drives. only red pixels are lit up and it looks like glitter.
Feb 06, 2008 | Televison & Video
JVC resolution problems
replace ..display defective....
Nov 24, 2007 | JVC GM-V42UG 42 in. Plasma EDTV
Jvc AV42PD20ES 42INCH TV
Hello gladwin6,
You may have at least a blown fuse. However you may also have other damage to your power supply. This often happens due to the voltage spike caused by the power coming back on suddenly. You can check to see if the fuse is blown, however once you change the fuse and if this does not take care of the problem, I would suggest that if you do not have a background in electronics, that you have a qualified technician take a look at your TV set.
I hope this helps,
Thank you,
Shuttle83
Oct 24, 2007 | JVC PD-42WX84 42 in. HD-Ready Plasma...
JVC GM-V42 42 in. Plasma Television Logo
390 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
