Question about Intertherm Heating & Cooling
I need a wiring schematic for an intertherm heat pump/furnace split model #E3EB-010H. can u help?
SOURCE:
the dr
  • 447 Answers
SOURCE: problem running heater
Its not good that you dont know where the air filter is. Odds are there may not even be one in place. In Most mobile homes they dont pay much mind to proper filtration. The heat strips are covered with dust. If the heat Strips are that bad then usually the whole unit is clogged. Is there a unit inside the mobile home?? Or is the unit outside quite large and have ducts running to it??
Posted on Nov 24, 2007
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
  • 58 Answers
SOURCE: need wiring schematics for goodman
you can get it from fixya te product section or you can take a look at the related links and thank you for using fixya
Posted on Jun 27, 2008
  • 69 Answers
SOURCE: wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Posted on Dec 21, 2008
  • 687 Answers
SOURCE: I need a wiring diagram for the fan motor
http://www.nordyne.com/literature/710235a.pdf
This is to your unit. Good luck!
Posted on Apr 09, 2009
Need a wiring diagram for a EEH-012H intertherm
Request the wiring diagram from Hunter and, if need be, Intertherm.
Feb 12, 2018 | Hunter Heating & Cooling
How to remove Heat strips from intertherm furnace to make an air handler? Wiring schematics
WHAT??? Removing heat strips does not make an air handler. Air handlers have heat strips, please explain
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 17, 2017 | Intertherm Heating & Cooling
How can I connect an Intertherm furnace with a heat pump to a new Honeywell thermostat?
Ensure that that thermostat is for a heat pump and has connections for the emergency heat strips.
Feb 02, 2016 | Heating & Cooling
Where on internet can I find a diagram of the furnace listed below?
Google that number. Find manufacture, go to their site search customer support or contact us. Ask them for it.
Mar 05, 2014 | Intertherm E3EB-017H Furnace 17Kw 2
I have a E2EB-017HA air handler and I want to change it to a variable speed motor. Is this possible
Some companies do sell a variable speed kit. It includes the motor and controls. Get your model and serial number of your unit and contact your local Payne dealer. The can locate the proper kit if available for you.
Feb 03, 2013 | Intertherm E3EB-017H Furnace 17Kw 2
Intertherm Heat Pump
Some of the old heat pumps made the reversing valve in the heating mode. On your new thermostat the orange wire will need to be on the B terminal. If it was color coded? I hope you made notes of how it was.
Jan 05, 2010 | Heating & Cooling
Intertherm furnace heat pump combo had a small fire in the control wiring when a contactor for the heating elements burnt. I am an electrician by trade and have replaced all the wiring and contactors but...
ok the transformer has a common which is black the second wire red is coming from the contactor side at 240 volts the last wire on the side opposite the common and 240 connection goes to the 24 volt side of the contactor. Hope this helped
Dave
Oct 13, 2009 | Heating & Cooling
Heating & Cooling Logo
87 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
