Question about Lutron Dalia 3Way Dimmer 600W- White - With Claro Screwless Wallplate
I have a DL-3PSLHW-WH switch with no wiring diagram. It is single pole or 3-way. Need diagram.
You posted under Lutron 3-way dimmer.
You didn't say the number of screw terminals on device or color of those screws.
If your device has two brass screws, then it is single pole.
If your device has 2 brass screws and 1 dark screw, then device is 3-way
If you are replacing 3-way switch, identify wire on dark screw >> connect this wire to dark screw on dimmer. Other two wires connect to either brass screw.
If device has wires instead of screws, the color of those wires is an important clue.
Answer back with the colors of those wire and it is easier to help.
Different dimmers are suitable for different types of lighting.
In an effort to help you, I searched my files for Lutron dimmers.
Lutron has 17 dimmer types, with numerous models under each type
They don't show DL-3PS
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
Lutron has NT-3PS
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/NovaTDimmer/Pages/ModelNumbers.aspx
The NT-3PS is a 3-way dimmer.
Here is wiring manual:
http://www.lutron.com/TechnicalDocumentLibrary/wallbox_wiring_6_7.pdf
If the help above does not get you going, answer back with more information and we can help.
Posted on Oct 24, 2010
SOURCE:
I need a wiring diagram for two switches and one light
I f you intend to run one light with two switches you should opt for 3 way switches. the wiring diagram is usually inside the box if you by them boxed.
Mar 08, 2014 | Pass & Seymour / Legrand 1595-2SWT...
Separate 1 switch 3 lights
You need separate wire going to each light.
Here are diagrams:
2 single pole switches, before you started to replace
http://waterheatertimer.org/images/2-single-pole-switches.jpg
Single pole and 3 pole to control each light separately: must identify black wire to each light. If each light does not have separate black wire inside the switch box, then it is not possible.
http://waterheatertimer.org/images/single-pole-and-3-pole.jpg
Add a comment
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 05, 2013 | Electrical Supplies
Wiring diagram, need help installing.
Single pole switch?
http://waterheatertimer.org/How-to-wire-switches.html
Add a comment and describe product and application.
Apr 10, 2013 | Leviton 5601 Decora Single Pole Switch, 15...
How to wire a two way switch for a staircase
Copy following link for 3-way switch wiring diagram:
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Add a comment and say if you are adding a 3-way switch to existing single-pole switch.
You need 3 wires running to new 3-way switch.
Mar 16, 2013 | Electrical Supplies
Hi, How do you wire a Leviton switch to the next switch in a 4 gang box? Diagram? Thanks! Michael
Switches are not identified.
Single-pole switches are wired differently than 3-way.
Wire colors are not identified. Some boxes have red and black wires that carry power.
Add a comment and fill out details after studying image and reading information.
I am not there, so you can also add a comment and include in-focus photo of your switches that you posted on Flickr.
Following image shows single-pole switches, with typical black and white wires.
No bare copper ground wire is shown. Ground wires connect to green screw.
http://waterheatertimer.org/images/Single-pole-switches-in-4-g.jpg
So your new switch has 2 brass screws. No white wire connects to single-pole switch. One screw will have 1 black wire that goes to light fixture. The other screw will have 1 or 2 black wires that jumper or connect to the other switches as shown in image.
White wires are usually twisted together and covered with wire nut and pushed to back of box.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Leviton 15a 120v Sp Switch
I need a diagram of a two way switch
Switches are single-pole, 3-way and 4-way.
There are other types of switches also, but none are directly called two-way.
Single-pole is when 1 switch controls lights:
http://waterheatertimer.org/images/Single-pole-switch-300.jpg
3-way is when 2 different switches control same lights.
4-way is when 3 or more switches control same lights.
http://waterheatertimer.org/ST01C-program.html#3-way
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Feb 21, 2011 | Hardware & Accessories
Describe your how to install a ipp15-1l Problem
1) First of all you need to determine what device you are replacing. Single-pole or 3-way.
Add a comment any time
Remember you can also take advantage of fixya phone service, where expert speaks to you over the phone while you are installing device. This service is not free.
2) If you are replacing single-pole switch, that is where one switch controls the Load (light fan motor)
Here are instructions for installing ipp15-11 Motion switch for single-pole replacement.
Old switch has 2 insulated wires plus bare ground wire.
Ipp15 bare copper ground wire will connect to bare copper ground wire.
Separate switch wires for testing.
Use ordinary two prong tester, tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire will connect to ipp15 screw marked BL black.
The other wire that came off switch will connect to ipp15 screw marked RD red
Hot wire is identified.
Located in back of box are white wires that are twisted together and covered with wire nut. Remove this nut.
Now test Hot wire to all other wires in box, excluding bare ground wire.
Tester lights up on neutral wires. ipp15 screw marked WH white connects to neutral wires.
If your box does not have neutral wire, then connect ipp15 WH white to bare ground wires.
4) If you are replacing 3-way switch, that is where 2 different switches control the same Load (light fan motor.
3-way switch has 3 insulated wires and a bare ground wire.
Note screw colors on old 3-way switch. Dark screw is the Load wire. The 2 brass screws are the travelers.
From the ipp15 instructions, it appears you will need Viza Coordinating Switch Remote plus a sensor device to accomplish the 3-way installation.
If you have both of these devices and want free written instructions, then add a comment and I will verbalize contents from the manual.
Also you can pay a fixya expert to talk over the phone.
5) Leviton also offers technical assistance at 1-800-824-3055
Dec 27, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
LOOKING WIRING DIAGRAM SL-6107-IV-C
This is a 3 pole switch, made by Cooper
Black = Hot or Load
Green = Ground
Brown and Red are travelers.
Link to proper literature regarding this switch:
http://solutions.cooperwiringdevices.com/webDB/documents/cwd%20residential/instrSheets/469MT-PTA%20(REV.%20A).pdf
Oct 08, 2009 | Heath Zenith Occupancy Motion Sensor Wall...
Problem w/new sliding dimmer
The problem is that the Cooper #9530DS-K-L is actually a 3-way switch and you need a single pole dimmer switch to replace your existing single pole toggle switch.
If you want to use the Cooper switch you have you can take one of the black wires and cap it with a wire nut and connect the other two wires, but frankly, you'd be paying about 2 times the price for a 3-way dimmer switch when you only need a single pole switch.
You should be able to return the switch and get the correct one.
You should only have (2) black wires on the proper replacement switch, plus a ground wire
Hope you found this very helpful and best regards!
Aug 07, 2009 | Electrical Supplies
Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
Mar 03, 2009 | Pass & Seymour / Legrand 1595-2SWT...
Lutron Dalia  3Way Dimmer 600W- White - With Claro Screwless Wallplate Logo
517 people viewed this question
Top Lutron Electrical Supplies Experts
jdthefixer
Thomas F. Schneider
mpservices
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
