One of my laptop speakers on my Dell Inspiron 1420 just stopped working so the sound isn't as loud as it should be. Where do I go to fix it?
  • michaelxfire Oct 24, 2010
    Yeah, it most definitely is the left speaker that doesn't work. I need to know what place I can go to that can fix it...without me spending a lot of money
    Brigadier General:
  • 8,909 Answers
I would plug a set of headphones into the sound output socket. That will prove if there is a problem on the board of if the speaker is faulty. If you have only one earphone working, then you have a problem with either a balance control or the amplifier.
Check the dersktop audio controller settings. If all looks balanced then there is a good possibility that the amplifier is faulty, if one side is down, adjust the balance control.
Posted on Oct 24, 2010
  • specialistel Oct 25, 2010
    I thought it would be the lodspeaker.
    I think you could do worse than to look on somewhere like ebay or ask a dealer if they have a scrap laptop in with a good speaker.
    Regards
SOURCE:
Why no sound
Anonymous,
First open up the sound properties icon on the taskbar and verify that nothing is muted. You can download and install the Audio Drivers for the Inspiron 1420 at the link below.
Inspiron 1420 Drivers
http://dell.to/1wRqjWS
Thank You,
Dell-Jesse L
DellCares
Dell Social Media and Communities
Jul 18, 2014 | Dell Inspiron 1420 Laptop
My dell inspiron 1420 laptop stopped giving any sound.
my guess is either ur speakers blew or there is a loose connection somewhere. go on youtube n search for how to open ur laptop. once you get it open you should be able to see if anything has disconnected or not.. good luck hope this helped
Dec 31, 2012 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
MY DELL INSPIRON 1420 WHEN I PLUG IN BUT NOT CHARGING HOW TO FIX IT.
Hello, you may find this to be the fault of the charger itself. Dell chargers have a micro thin communication wire that tells the battery to chage and when to stop charging. But this tiny communication wire within the charging cable is very fragile. If it breaks inside, then the laptop battery will not recieve the signal to make it charge. Replacing the laptop charger may be your solution. But it will need to be another Dell charger compatible with your laptop
Dec 23, 2012 | Dell Computers & Internet
My laptop speakers has stopped working.?
this type problems are usually caused when the sound driver of the system are un-installed so the and like wise when the speakers are damaged.
Solution is to Download the Sound Driver of you the MODEL of your laptop so as to install on your system.
like is the speakers are damaged? meet a laptop technician to change it for you
Dec 22, 2010 | Dell Inspiron 1420 Notebook
I have dell Inspiron 1420, i reformatted my system using windows vista home edition but after proper installing all software my internal speaker doesn't work please advise;
It must be a Volume device drive problem,please try to update your volume device drive software,find your original dell Inspiron 1420 volume device driver software or download it from www.dell.com
Oct 05, 2010 | Dell Inspiron 1420 Notebook
No sound from speakers on inspiron 1420
Try to update sound card drivers.
Mar 09, 2010 | Dell Inspiron Notebook
My dell inspiron 1420 has no sound. it appears
driver is wrong.try to install sound card with original cd driver.
Aug 01, 2009 | Dell Inspiron 1420 Laptop
Left internal spkr not working
Try connecting an external set of speakers or headphones, see if you get both channels, if you do, then the speaker assy is bad and needs replacement.
If you only get audio on 1 channel externally, then check all the sound settings in Control Panel (make sure correct speakers are selected and the playback settings are all correct.)
Jun 29, 2009 | Dell Inspiron 1420 Laptop
How can i raise the volume on my dell inspiron 1525
Here's how I fixed mine with Win-VISTA:
1. Click START
2. Click CONTROL PANEL
3. (Switch to CLASSIC VIEW)
a. Click on SOUND
b. Click on PLAYBACK Tab
c. Click on SPEAKERS/HEADPHONES
d. Click on PROPERTIES
e. Click on CUSTOM Tab
i. Make sure PC SPK MUTE is NOT checked
f. Click on LEVELS Tab
i. Slide PC SPEAKER to 100%
ii. Don’t worry about the SPEAKER slider, it’s controlled by the keyboard buttons
g. Click on ENHANCEMENTS Tab
i. Make sure LOUDNESS EQUALIZATION is checked
h. Click OK
i. Click OK
4. Close CONTROL PANEL
Dec 20, 2008 | Dell Inspiron 1525 Notebook
Open Questions:
Aol verizon support phone number +{1-855*536*5666*} -Aol verizon Customer Service- XXUNKWM Aol verizon is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Aol verizon email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Aol verizon support number When you are using the Aol verizon for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Aol verizon support number and ask for the help. Once you dial the Aol verizon customer support number, you come in contact with a team of experts at the Aol verizon customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Aol verizon support phone number will help you with that simply and quickly. This is Aol verizon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Aol verizon agent. Features of Aol verizon support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Aol verizon customer support phone number. Here are some of the features of customer service: The Aol verizon customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Aol verizon customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Aol verizon provides you the facility of Aol verizon support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Aol verizon. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Aol verizon Customer support number team.
Oct 18, 2019 | HIS Computers & Internet
Computers & Internet Logo
59 people viewed this question
Ekse
Alun Cox
