Sony KV-32V40 No picture or sound, "stand by timer" light flashing. Have Direct TV DVR which comes on fine. HELP!!!! No owners manual. WHILE ATTATCHING A WIRE WRAP A SCREW HIT THE S-VIDEO CABLE.IT BLEW A BREAKER & AFTER THAT TV WOULDNT TURN ON. DO NOT HAVE MANUAL.
    Genius:
  • Televison & ... Master
  • 1,689 Answers
You made a powerful short if you blew a breaker! There has to be damage to the circuit area that is related to the S-Video input.
The input circuit IC and possibly some other support components have been damaged. This IC may no longer be available.
I don't think the service manual is still available from Sony. They were charging $60 US for the manual when it was available.
Jerry G.
Posted on Jun 08, 2008
Sony KV-32V40
I'll let you know if the user manual is available.
Jun 09, 2008 | Sony KV-32V40 32" TV
My sony KV-32V40 has worked well for a number of years. All of a sudden, there's no picture, but the audio is perfect. The timer/standby light flashes a number of times at startup, but the picture never...
I would expect, based on your description, that it is likely a bad solder connection on the main board. The internal connections can develop small cracks over time and eventually become intermittent. There are other possibilities, but this is a likely one. Whatever the source of the trouble it would need to be diagnosed by a technician. I would find a technician or shop that can give you an estimate and you can base your repair decision on that.
Nov 25, 2009 | Sony KV-32V40 32" TV
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
No picture, no sound, stand by timer light flashing
Need a little information here...
1. The TV remains on, yet there is no picture and no sound? Or does the TV turn off altogether?
2. How many blinks does the standby light give? Are they continuous? Is it the same each time, or random?
3. Did anything else happen before this, or did it just happen one day?
Answer that and I'll try to help with what I know.
KV-32V40 32" TV Problem:
1. The TV remains on with no picture, but the sound is fine?
This problem is indicative of a problem with one of three (of the same) ICs. Give me a bit more info and I'll give you some links to the solution, or help you myself.
Nov 24, 2007 | Sony KV-32V40 32" TV
No picture but sound ok
HI,YOUR PROBLEM IS ON THE FLYBACK TRANSFORMER OF YOUR TV. YOU MUST REPLACE THIS BUT BE VERY CAREFUL REMOVING THE FLYBACK.
Nov 22, 2007 | Sony KV-32V40 32" TV
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Sony KV-27S42 not on but timer flashes
The blinking light means almost 100% that the high voltage circuit has failed. Probably need a new horizontal output transistor and flyback. Perhaps an associated resistor or diode. If you have the expertise go for it, otherwise take it to a professional. In any case be extremely careful and safe. Good luck.
Jun 21, 2006 | Sony KV-27S42 27" TV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
