Question about Panasonic Lumix DMC-ZS3 Digital Camera
Viewfinder is displaying multiple lines and I cannot see object that I am trying to take a picture off.
  • sbkenny Oct 24, 2010
    No, I am only able to see a small portion of pictures taken earlier. The viewfinder is displaying the same lines in both picture taking mode and displaying pictures already taken.
    I am in U.S.A. and the camera was purchased new last November so it should be still under warranty. Thanks
  • 4,889 Answers
Are you able to see the pictures that were previously taken? Just trying to find out if its a LCD related issue or image sensor related.
Posted on Oct 24, 2010
  • eagle338
    eagle338 Oct 24, 2010
    IN that case it sounds like an LCD panel issue. Replcing the panel should resolve the issue. You may have to send it to an authorized panasonic service center. But first call up their tech support and get a quote. Sometimes the cost of this repair is nearly as much as the cost of the new cam. Please let me know the country you are located in so that I can get you the contact info of Panasonic customer service center.
  • eagle338
    Yes it should be under warranty. Contact product support at :
    1-800-211-PANA (7262)
SOURCE:
My canon 70d does not zoom and focus automatically
My guess is the self timer was accidently turned on
Description
Using the Self-timer on the EOS REBEL T3i.
Solution
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
Attention:
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
NOTE:
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
Sep 02, 2017 | Canon Cameras
So I have an EOS Rebel Xsi, and it has been working perfectly for the last couple of months. I turned it on and tried to take a picture in MF, but then a yellow light on the front starts flashing and...
Sounds like the self timer was accidently set.
Description
Solution
3. Press <Cross Keys> to select the desired self-timer, then press the <SET> button.
: 10-sec. self-timer (The remote control can also be used.)
: 2-sec. self-timer
: 10-sec. self-timer plus continuous shots. After selecting , press <Cross Keys> to set the number of multiple shots (2 to 10) to be taken with the self-timer.)
4. Look through the viewfinder, focus the subject, then press the shutter button completely.
Attention:
NOTE:
Sep 03, 2017 | Canon EOS Rebel XSi Digital Camera
How do I display a grid in the viewfinder when taking pictures?
Are you sure you saw this in your D40x?
I know this is in my camera under personal settings and called raster in viewfinder. But I can't find anything in the D40 or D40x manual.
Oct 14, 2012 | Nikon D40x Digital Camera
Problem with viewfinder - focus?! I've been using my Nikon d3000 for over a year now. Few days ago I tried to take a photo but when looking through the viewfinder, the photo wasn't focused. It was...
There's a diopter control near the viewfinder to adjust the viewfinder to your eye. Try adjusting that while peering into the viewfinder and try to get the focus brackets and the data at the bottom of the viewfinder into focus.
Jun 20, 2011 | Nikon D3000 Digital Camera
A hair like object seen through the viewfinder.
Hello
Thank you for using FixYa for your problem
there is some hair/dirt in the viewfinder, above the lens
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Rollei QZ35W Point and Shoot Camera
The viewfinder is not acculimented with the telescope. what i see in the viewfinder is not visble in the eyepeice of the telescope what i see in the viewfinder isnt in view in the scope . how do i...
Point the scope to a distant object like the top of a telephone pole.
Without moving the telescope adjust the small screws on the finder scope to LINE-UP on the same object.
Nov 21, 2009 | Meade TeleStar 60AZ-A Telescope
Nikon D40 Monitor blank when shooting picture. Viewfinder OK
while using slr cameras u always see in the viewfinder bcuz slr is a single lence refleime u can see the picture after shoot by clicking on play back option this is a feature of an slr camera
Nov 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
SONY DCR-SR300 with CMOS viewfinder
I suddenly had similar problems with my SR300. I replaced the flat ribbon cable (looks orange) between the body and the LCD display and camera works like new. The ribbon cable is subject to cracking the internal wires where it flexes when you open and close the LCD display. There was also a new part number for the cable so I suspect it is a known problem.
Sep 02, 2008 | Sony Handycam DCR-SR300 Camcorder
Blured viewfinder
Look at the viewfinder on the camera.
Now look on the LEFT side of the viewfinder; just above the swivel-screen.
You will see a little thumb wheel there.
That is the focus for the viewfinder. Move it up and down to bring the viewfinder into focus. (Don't forget to do this while you are looking through the viewfinder so you can see what you are adjusting.)
Easy fix. :)
Sep 29, 2007 | Canon PowerShot S3 IS Digital Camera
E370 Camera Fault:
change your cmera or the ribbon
Sep 03, 2007 | Samsung SGH-D500 Cellular Phone
Panasonic Lumix DMC-ZS3 Digital Camera Logo
61 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
