I have a digistar tv and it shows that it's locked and I don't know what to do remote and the button on the tv dont work
    Top Expert:
  • Televison & ... Master
  • 76,140 Answers
[1019 _0165]
Hello
You just try with one amoung the above four digit code to open your TVs lock. Swich off the set, and swich it again On during each code test. Ok
Proceedings
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Wish you sucess.
Posted on Oct 25, 2010
SOURCE:
I NEED A REMOTE FOR A DIGISTAR TV MODEL #TK1337DW SERIAL #135800TS1337022607
sorry but fixya does not sell parts nor would we know where you find a Digistar remote if not from the manufacturer
May 13, 2018 | Televison & Video
I have a Digistar HD LCD TV model LC-4010D. I have no remote for the TV. When I turn it on, the blue light turns on to show that it has power. But no picture or sound appears. It is currently plugged into...
I'm not familiar with the tv set, however here are some things to try.
It's possible that the tv powers up in stand-by mode, so you'll need to find a way to turn it on completely. See if there are channel +/- buttons on the tv and try them.
If the remote might be necessary, try to see if you have friends/family with a universal remote control, such as a Logitech Harmony, to lend to you for testing. This way you can avoid spending money for nothing on a remote.
Googling on this brand and model gives a lot of negativity though: a lot of problems posting, but no support or even an online manual. Personally I've never heard of Digistar. It might've been a bad investment.
Oct 17, 2013 | Televison & Video
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
My videocon tv is locked tv or remote button is not working monitor showing sorry tv locked what i do
Sunil u ******* u dont know anything u r dumb. press and hold Lock buttonto unlock
May 03, 2011 | Televison & Video
ON MY DIGISTar tv,there is lock symbol that has appeared on the upper left side. There is no fix for this in the user manual
i just had the same problem and found that if you hold down the display button on the remote for about 5 seconds it seems to lock and unlock the tv.
Feb 20, 2011 | Televison & Video
Codes for 20" Digistar model tk2055d tv remote
THE BEST SOLUTION IS THE SIMPLEST ONE.
I suffered for 1 month shopping around for an universal remote control that has a code for the Digistar tv brand. It was in vain.
So just turn to the simplest way ..the programming with code search (on the guide of the universal remote control- which has not the code for digistar brand) In the paper it tell you exactly what to do. I bought a 3 device universal remote control.
On mine it showed five easy steps to follow and the remote finds itself the code and programs it .You do not put any code ever, the remote just simply WORKS perfectly. I have solved this problem just 5 minutes ago..Oh ...I forget..On the universal remote control instruction it said that you might have to press the ON/OFF button up to 200 times , so i thought "I never tried this one, better then waist days and months will no solution. I nedded to do it only for 30 times or so beffore the TV turned OFF, and than I pressed the ok button on my remote (probably to save it- or who cares-as long as you follow the instructions). Then I could turn back on the Tv and P{LAy with the remote without putting any code as the remote it programmed for the Digiistar brand..I'm so HAPPY...Try it and spread the "new"...It is Ironic ..it was there all the time...we look in more complicated zones and do not see the solution sitting under our nose:((:)))
GOOD LUCK!
Oct 19, 2008 | Televison & Video
Lock key on screen
Hold down the "display" button on the remote until the picture comes back. The manufacture phone number is 1-866-220-7116 for future reference. (Just in case) Thanks! //D
Apr 25, 2008 | Computers & Internet
Need code
try code 238, if it does not work you will need to try the code search.
1) turn on tv
2) press and hold "code search" until indicator light comes on
3) release code search
4) press and release "tv", indicator light should blink once
5) aim remote at tv and press the power button until the tv turns off (you may have to press it 200 or so times)
6) once the tv turn off, press enter on the remote
Nov 17, 2007 | RCA RC-U703SP Remote Control
Televison & Video Logo
251 people viewed this question
Top Televison & Video Experts
Ekse
