Question about LG GW300 Cell Phone
I try sending a simple text message and i have full signal,but it just keeps faiing,ive tried talking my sim card out,but its still not solved the problem,any ideas Ryan.
    New Friend:
Check whether the sms centre no. is present or not...
follow these steps:
open messaging>settings>text message>text message centre
there should be a number
if its not present, contact ur service provider n ask for the no.
or else reset the phone
use 1809#*300#
Posted on Oct 31, 2010
SOURCE:
Can't send or receive text messages
It is likely that the phone has 'dropped off the network' or your message centre number has been accidentally changed.
The phone periodically sends a signal to the network to keep the network updated with its location. That way, when a call or text is made to your phone, the network knows which CELL to send the signal to (the last CELL place the phone was found in). If the network has not received a signal from the phone saying it is being turned off or has not managed to keep the network updated, the network will not deliver a text although this should not affect sending texts (in theory).
To get it working again, there are a few things to try:
1. Remove the battery without turning the phone off, remove the SIM and power up the phone. When the phone has started, turn it off, re-insert the SIM and start the phone.
2. Go into Network Settings and manually try to connect to another network and when it fails, set it back to automatic.
3. Temporarily put your SIM into another phone for a minute (you could get lots of texts coming in so read them before you put the SIM back into your phone.
Sep 04, 2014 | LG Cell Phones
Tip
Phone Cannot Send or Receive Calls and Text Messages: A Simple Electronic Glitch
It is frustrating when only your phone cannot send text messages no matter how strong the network signal is. Sometimes you feel nobody cares about or remembers you because nobody calls or texts you but actually there are. Your phone just can't be reached or can't receive text messages. When these happen, turn off the phone; remove the battery and then the SIM card. Insert the SIM card to another phone and try sending text messages; if you still cannot send text messages, remove the SIM card and let it sit off the phone for at least fifteen minutes then insert it gain. You should be able to send text messages after that, but make sure you have credits.
The next thing you should look into is the phone. Make sure network signal is present then insert a known good SIM card in your phone and try sending text messages. Reset the phone if you still cannot send text messages, but back up important files and data, such as contacts, videos, images, and messages, before doing so.
One simple way to "reset" the phone is by removing the battery and letting it sit for at least fifteen minutes. Another way is by restoring the phone settings to factory settings. Simply navigate to settings then phone settings and select "restore to full factory settings" depending on the brand and model of the phone.
This tip is not intended to solve virus or firmware problems but rather to avoid unnecessary visit to the service center and save few bucks from a problem only caused by a simple electronic glitch. Check the network signal strength and your credits before jumping into any conclusion.
on Apr 06, 2010 | Cell Phones
Says the text messages are full - there no text mgs at all - cannot recieve or sent text either. Says I have voicemail - no voicemail in there. makes a vibrating noise when calls are places, when text is...
it sounds like you may have used the memory installing apps try either uninstalling a few or put them on the memory card thus freeing up the additional memory required for the txt messages ive had this happen with my phone uninstalling or sending the apps to the memory card shold slove the issuse you can send them to your memory card by going into settings selecting the app you wish to move then clicking the tab that will say move to sd card or something similar have a great day hope this is helpfull
Aug 16, 2011 | LG GD510 Cell Phone
Vortex --when I try to send a text I get the message "phone storage is full- delete some files to free space." I've deleted all messages and still can't send. Don't text nearly enough...
Most phones have both internal memory and the sim card is a memory on its on. You might have the function to keep a copy of sms in sim as well. So you need to enter the sim memory and delete those SMS's
http://www.lg-expo.com/lg-expo-general-support/sim-card-full/
May 10, 2011 | LG Cell Phones
My lg versa isnt sending text msgs. every time i try, it says it failed then it tries again then says message not sent. invalid destination. i have the right number and ive turned it off a bunch of times...
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jan 26, 2011 | LG VX9600 Cell Phone
I had the same problem.... i could not send text message with my N79.... it's just stored in outbox and keeping on trying to send but it never been sent.... i had checked all the settings on my phone but...
Hello,the problem you are facing now is simply because you have deleted your message center number mistakenly,kindly visit your message center number through your messages icon menu,you then move to message settings there you would see your message center number.if just a digit is deleted from the message center number you will not be able to send messages.all you need to do is to look for someone who is on the same network with you to copy out the message center number correctly and compare with the one you have on your phone,or you can slao get the message center number from your service provider.
take care.
Dec 05, 2010 | Nokia N79 Cellular Phone
Phone works but says "no service" iFOE Mod. # P168
suggestions:
  • try inserting a new SIMcard of similar network, and if this work with your phone, secure a good signal.. then try sending a simple message.. then recieving a message..
  • try inserting a new SIMcard of different network, and if this work with your phone, secure a good signal.. then try sending a simple message.. then recieving a message..
  • if both/either this doesn't work, try getting back your original phone settings...
  • still doesnt work? have your phone serviced by a qualified cellphone technician..
Nov 28, 2008 | Dual Electronics CECT P168 Cellular Phone
Outbound Text Message
It's a operator message. Your SIM card need to send a message to the operator to inform something about your phone (like you are using a new phone) but the receiver don't recognize for what the message is. Your sim card will keep sending the message until it receives a valid response.
Try to change the SIM card and see what happens. If the problem appears only with one card, you may ask your carrier company to change it.
May 05, 2008 | Motorola Mobility RAZR V3
LG GW300 Cell Phone Logo
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
