Question about Janome Sewing Machines
I have the Janome 6600 P. Beginning a seam the thread knotted and the machine made noise and needle would not move either up or down. I manually moved the needle using the handwheel and cut away the knotted thread. I began sewing again but instead of starting at the edge began about a half inch down, forward stitched, reversed to lock threads and problem repeated and received the message to "Stop for safety purposes". Did that. Referred to the manual, tried manual recommendation. Did not work. I then received a warning sign on the screen "E5 Error". And now I am contacting an expert.
  • Janome Master
  • 12,731 Answers
The machine may have been knocked out of time and the safety device activated.
Search for:
Make Model error E5
As a suggestion, when you thread the top thread, be sure to ALWAYS RAISE the presser foot. This allows the thread to fully seat in the tension disk which will help prevent that "thread nest," or as I call "thread-barfs," at the beginning of your stitching. It also helps to pull the bobbin thread to the top of the fabric and then gently holding both thread tails in your left hand while slowly taking the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Posted on Apr 17, 2017
  • Janome Master
  • 690 Answers
Replace the needle.
The tension on the bottom may be too tight(loosen) or the top tension may not be tight enough (tighten). Try to fix with the top tension being tightened first.. Move the hand wheel first for a couple of rounds. If it is still a problem the bottom tension will need to be loosened. Always make sure all of the old threads are cleaned out thoroughly. Now, here is a problem chart to look at if this isn't a fix.
E5: The machine is jammed or the foot controller is defective. A. Replace the foot controller. B. Check for a tight or stuck clutch by the hand wheel. C. The machine may be jammed. Remove the timing belt to locate whether the bind is on the upper shaft or lower shaft. If it is the upper shaft, there may be thread caught in the take-up lever or crank pin. If the lower shaft is binding, check hook clearance, hook backlash. D. If you continue to have the problem, loosen the screws that hold the metal, lower shaft supporter. While the machine is running slow-to-medium speed, tighten the screws. E. Clean the sensor on the DC motor and check if the shield plate on the motor is not loose or hitting the sensor. If either the sensor or shield plate is damaged, replace the motor. F. Check the lower shaft sensor. Make sure the shield plate is going perfectly thru the middle of the sensor. Replace the sensor and/or shield plate if damaged. G. If you still get the error, replace the DC motor or lower shaft sensor (in this order).
Posted on Apr 16, 2017
2 Suggested Answers
SOURCE:
e-Guru
  • 3917 Answers
SOURCE: while using the pin stitch
Please go through the link given bellow to have the resolution to your problem...
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 27, 2010
I have a janome 6600. The stitches started jamming up and breaking.What might be causing the challenge with the stitches?
Difficult to say without really seeing what's happening and which thread is breaking. If the top thread is breaking, check to make sure the thread is not wrapped around the spool pin or a thread guide.
Just some things to try:
Install a brand new needle.
Be sure to clean and remove all the thread pieces, lint, etc from under the needle plate, around the shuttle, etc. Oil as instructed in the owner's manual.
Remove all the thread from the machine. ALWAYS RAISE the presser foot when threading the top and rethread the machine from the beginning. Check that the thread path is correct and the bobbin is loaded and threaded correctly.
Be sure to use good quality thread--no Old or bargain bin threads!
Solve Most Sewing Machine Problems With These Simple Tips
Why Does My Sewing Machine Keep Jamming Sewing Made Simple
Feb 11, 2018 | Janome Sewing Machines
My janome magnolia was working just fine and then all of the sudden the bobbin thread keeps knotting up. i've gone over all troubleshooting, cleaned out the lint, replaced the bobbin - all to no avail......
This happened to me on several occasions and finally one service tech told me not to use the needle down auto button. Instead when threading the bobbin just move the wheel toward you slowly until the thread catches.
Jul 08, 2014 | Janome Magnolia 7330 Sewing Machine
Why does the needle keeps getting stuck in the bobbin
Sounds like you've got a thread jam going on. Take the bobbin and bobbin case out, take the needle plate (=throat plate) off the machine, and clean all the lint and bits of thread and other gunge out of there. Reassemble. Rethread with the presser foot up. Fetch up the bobbin thread and pull bobbin and top thread ends under and behind the presser foot. Then start each seam like this:
1. Fabric under the presser foot; lower needle with handwheel or needle up/down key into the beginning of the seam.
2. Drop the presser foot.
3. Hold the ends of the bobbin and top thread behind the presser foot while you take the first 2-3 stitches
4. Drop the thread ends and sew normally.
See also the last pair of photos here: http://www.picturetrail.com/sfx/album/view/22521551
Feb 10, 2014 | Janome Hello Kitty 11706 Mechanical Sewing...
Cant get my bobbin in right position it keeps knotting up on inside of fabric
Top thread problem, Not enough tension on top=loops on the bottom of the fabric; too little tension on the bottom = loops on top of the fabric. Yes, I know it seems backwards. See: http://www.picturetrail.com/sfx/album/view/22521551
Dollars to donut holes, you either threaded the top of the machine with the presser foot down (it has to be UP to let the thread into the top tension), or you're trying to sew with the presser foot still up (which is an issue common to people trying to sew bulky seams).
Take the thread off the top of the machine, take out the bobbin case and give the machine a cleaning, rethread the machine, fetch up the bobbin thread and hold the bobbin and top thread ends together under and behind the presser foot for the first 2-3 stitches of each seam.
Jan 26, 2014 | Brother LS-2125 Mechanical Sewing Machine
Can not get machine to work, no manual, knots up and breaks thread right away 20 15516 machine can you help?
First check in the bobbin area for lint, bits of thread wrapped round parts.
Then make sure your needle is oriented and inserted fully.
Also when starting a seam be sure to grasp both of the threads and hold them as you start to sew.
If you still have problems, make sure your thread and needle are suitable for your fabric.
Since you don't really say where it knots and breaks ... it could also be a damaged needle plate.
Oct 05, 2012 | Kenmore 15516 Mechanical Sewing Machine
Machine starts to sew then upper thread knots up on underside of fabric
Do each of these steps one at a time and then test a seam on scrap fabric of the same type.
1. Make sure you thread the machine correctly with the feed dog lever in the up position. (this opens the tension discs, allowing the thread to seat correctly)
2. Make sure your needle and thread are the correct size for the fabric and that you've oriented the needle correctly and have it fully seated into the needle bar.
3. When beginning to sew a seam, always grasp both threads and hold them as you begin to sew.
4. Loops on the bottom of the fabric means that the upper tension is too loose. Tighten the upper tension a little at a time until loops disappear.
Good luck.
Sep 22, 2012 | Brother XL-2610
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
Thread is knotting up on bottom of fabric causing it to stop
1.check the needle & see if it's bent--if so replace
2.lay the needle on a flat surface & roll the needle over if it doesn't roll true replace
3.check for blunt needle-if needle makes a popping sound when needle penetrates fabric
4.needle is not all way up in holder
on my mechanical sewing machine sometimes the threads come off the take up lever, that causes the thread to bunch up under something I'm working on
also check thread in bobbin
Jul 28, 2010 | Janome 4623 Mechanical Sewing Machine
Sewing Machines Logo
265 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
