Question about Kenmore 61274 / 61279 Bottom Freezer Refrigerator
I have a model 596.69872990, and the freezer is working fine but the refrigerator is warm. any ideas?
SOURCE:
eagle338
  • 4889 Answers
SOURCE: my refrigerator is warm
This problem is due to plugged defrost drain line..Click on the link below(i have already solved this problem).Note that this is generic problem with refrigiratorsand the troubleshooting procedure is same for any model or brand..
http://www.fixya.com/support/t226483-kenmore_50222000_help_me_please
Posted on Nov 06, 2007
the dr
  • 447 Answers
SOURCE: Jenn Air JCD2389GTW Refrigerator problem
Guys first make sure the freezer fan is working, then remove the lower rear panel in the freezer and inspect the coil for excessive frost, if there is than use a hair dryer to thaw coil completely. If you guys then post your full model #'s i can help with figuring out why the defrost cycle isnt working.
Posted on Jan 10, 2008
tech master
  • 120 Answers
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Posted on Nov 10, 2008
  • 31 Answers
SOURCE: KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
kram26
  • 544 Answers
SOURCE: My Kenmore fridge, Model 596-58692890
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Mar 24, 2009
Fridgidare model number FRS26R2AWI , My Refidgirator side is working fine but the Freezer side is warm I took off the the freezer Coyle cover in the back of the freezer and they are warm any ideas ?
This does not make any sense because the fridge section gets cold air from the freezer via the damper mechanism that allows air into that compartment. The usual complaint is that the freezer is not that cold and the refrigerator is warm.
If your evaporator behind rear freezer panel is covered with ice the issue is with the defrost mechanism/heater element.
If compressor is always running and the entire evaporator is not nice and cold then you may be low on refrigerant.
Sep 06, 2017 | Refrigerators
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
My Jenn Air bottom freezer refrigerator is too warm in the fresh food (upper) compartment. This just occurred today. The freezer works fine. Any ideas?
sounds like the FF(Freezer Fan) is starting to wear out. This fan problem is very hard to diagnose because the fan will still spin but not fast enough to circulate chilled air thru the freezer as well as the refrigerator.
Jul 30, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
Frigidaire FRT 22INLHW3 Top Freezer Please help?Freezer works fine, the automatic ice maker works fine but the refrigerator temperature stays at about 50 degrees and up and gets warm, I have cleaned the...
hi thanks for the question the freezer will work kind off ok, even if the fan in the freezer is . not working . check that check for frost on the freezer wall
Sep 29, 2008 | Refrigerators
Freezer cold but frosted up, Fridge Warm
If the freezer is packed to the top and the air ducts are blocked it can not share the cold air with the refrigerator and it gets warm. If this is the problem, then the next day it should get cool again! let me know.
If you decide you need service!
Here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Check the back wall of the freezer section for frost. If it is frosted you do have a defrost problem. Timer or heater related. More economical to repair than to buy a new system.
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore 61274 / 61279 Bottom Freezer Refrigerator Logo
143 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
