Question about Dell Latitude C840 Notebook
Battery on dell latitude battery shuts down even though full charged
    Guru:
  • Dell Master
  • 2,178 Answers
Does it work without the battery - just the adapter? Does it shut-down? If it does, then it's not the battery.
Posted on Oct 24, 2010
SOURCE:
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
Motherbourd fix
Check your battery, it may have run out of charge. Even when your computer is shut down, the charge still dissipates, although very slowly.
Feb 18, 2013 | Dell Latitude D830 Notebook
Battery light flashs orange continusly on a dell latitude d620 if i disconnect the power cord the computer shuts down
Two possible causes for flashing Amber battery light.
1) Your battery won't charge and needs to be replaced.
2) Your charging circuit for the battery is defective and then your motherboard of laptop will need to be replaced.
Oct 20, 2011 | Dell Latitude D620 Notebook
Edited by tech1: Battery problem on old laptop dell, the most common failure on any PC laptop/notebooks'and tablets.
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
Dell Latitude D610
This sounds like it might be some sort of virus or malware. Do you have anti-virus software installed? If you do, run a full scan of your system. Run it at least twice if nothing is found the first time. Windows doesn't typically tell you to press F1 to shutdown your computer.
If you don't have an anti-virus program installed, you can run the Windows Live One Care Safety Scanner from the web:
http://onecare.live.com/site/en-us/default.htm
May 17, 2010 | Dell Latitude D610 Notebook
The light for the battery charging on my inspiron 1300 Dell laptop is now flashing amber??
Means:
1. Your battery is low and needs charging which possably means you need a new battery.
2. A battery replacement is needed.
Dec 30, 2009 | Dell Inspiron 1300 Notebook
BATTERY PROBLEMS?
Hi
Latitude D620 battery module has a battery charge tester. First remove the battery or turn the laptop over and press the battery icon and the note the battery LED indication.
If there is no LEDs lite, shut down the laptop, connected the power Adaptor, install the battery and check if the battery charge LED lites up.
If it doesn't double check the power Adaptor. Latitude D620 is rated to use a 90W Adaptor. There is a 60W Adaptor (looks very similar to) but this is for other Latitudes and AMD Vostro systems.
If the Adaptor has the correct rating, then check below for more info;
1) [Very Likely] The battery may be faulty or end-of-life and needs replacing. Check the battery connector on the Latitude and battery itself for any broken or bent pins or bits.
2) [Possible] You have the wrong power Adaptor or the Adaptor is faulty. This however would not explain why the battery is undetected.
Start up the Latitude into System BIOS (F2). Under System > Battery information check the battery and AC Adaptor status
If the Latitude D620 has warranty you may open a warranty claim with Dell Support.
Mike
Apr 02, 2008 | Dell Latitude D620 Notebook
Note book dell latitude d600 power failure?
pls help.my dell latitude D600 has refused to come up,its battery is fully charged.nd if i plug the charger to main electric power and then plug to my laptop i noticed that the charger goes off.wht could be the problem??.
pls help,its urgent.
larisdena(lagos nigeria)
Mar 19, 2008 | Dell Latitude D600 Notebook
Laptop not charging
If the LED on the panel is ON, Probably the baterry is bad.
Or could be the power plug on laptop is broken.
Dec 01, 2007 | Dell Latitude D600 Notebook
Dell Latitude C840 Notebook Logo
104 people viewed this question
Ekse
Clive
Clive
