Question about Sharp Microwave Oven Microwave Oven
Fuse F2 - F8AH250V HAS FAILED Is it safe to replace this fuse I am an electrician but not a service man
3 Suggested Answers
SOURCE:
pgh_pa_guy
  • 2992 Answers
SOURCE: The food in the microwave is not heating up I have
Fuses seldom just go bad on their own, but it's safe to replace. Before you replace the fuse, squeeze the tabs of the fuse holder clips together a bit. Sometimes they don't grip the fuse tightly enough, and this can cause heating which damages the fuse. If the fuse blows again there is a bad part in the oven that will need to be located and replaced. For a small countertop oven, it's probably more economical just to replace the oven than to repair it.
Posted on Jan 02, 2011
Testimonial: "Thanks very much for your help I will try your suggestions."
I recently had the same problem with the F8AH250V fuse blowing, all functions :- grill, convection, turntable. light etc were working but no heat from the microwave, the problem was Magnetron failure
Posted on Mar 05, 2011
Why would the Amana AXP22 be kicking fuse?
You have a serious short circuit, I suggest you call for a service technician
May 31, 2018 | Amana Microwave Ovens
Why my rationla keep blewing fuses every 7 months and over heating.
Maybe you didnt put acorrect fuse size so check it on its body or onthe nameplate
Sep 16, 2014 | Microwave Ovens
The food in the microwave is not heating up I have tested the fuse (F8AH250V) and found that it has blown. Is it safe to replace this fuse (F8AH250V) on my microwave.
Jan 02, 2011 | Sharp Microwave Oven Microwave Oven
GE Spacemaker microwave JVM140G just stopped working - no power, no lights, no exhaust - NOTHING Is there an internal fuse? The circuit breaker is not tripped.
NO internal fuse. It is most likely, the magnetron, and or High power diode. As related In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
May 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave stopped working. PLEASE HELP.
Feb 19, 2010 | Frigidaire PLMV169DC Microwave Oven
SMEG SA35MX no longer heating. Light, fan & timer all still working but no heat. Approx 2 years old. Is there a fuse or other component I can replace myself ?
Feb 10, 2010 | Microwave Ovens
GE Spacemaker Microwave lost power
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Micro wave oven dead no power is there an nternal fuse or breaker?
It is seldom that easy, In all likelihood the mangnetron has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Jan 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our Sanyo Microwave Oven barely 14 months old refuses to heat anything.The electrics are fine, the Clock works and the turntable turns. I have requested help from your customer services and Argos from whom...
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron. You will need to remove the cover to expose the magnetron, and other components. I recommend calling for a service tech if you are not an experienced electrician. You will need to test the cut-off fuse to confirm magnetron failure.)))
Oct 26, 2009 | Microwave Ovens
Microwave Fuse
you can use any 8 amp fuse of that caliber even a bit larger if you had to.
Phil
Apr 14, 2009 | Daewoo KOG-867T Microwave Oven
Sharp Microwave Oven Microwave Oven Logo
519 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
