Question about LG RE-20LA70 20 in. Analog TV LCD Television
LG 20LS7D TV
I get audio but my screen is dark.
  • Anonymous Mar 15, 2014
    lg 20ls7d tv has audio but no video
    Genius:
  • 2,035 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key.
then the fly back unit is failed you need to resolder the contacts or get it serviced...............
Posted on Jun 08, 2008
I have a LG 50LA6200 LED TV, about 3yrs old. While watching it, the screen suddenly went black, the audio is fine.
In the dark with the set on do you see light if you look through the vent holes in the back?
Oct 19, 2017 | LG Televison & Video
Tv has died
When the TV is on, if you look at the screen and can see dark images, then you will need to replace both the inverters. The inverters drive/power the back light inside the LCD to show the images. You may have to try and different channels and or inputs to truly see if you can see dark images while the TV is on. If you are hearing audio from a channel or an input then you should be able to see the dark images if just the inverters are bad.
If the screen is dead black without any dark images, then typically your LCD screen/module is bad.
If the TV powers up (power supply is good), you have audio and the remote will work with the TV (the main board is good), the only parts left is the inverters or the LCD screen/module.
I can get you LG part numbers if you need them.
May 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Screen on LG goes to black right after turned on.
It looks as if the backlights are being switched off at start up, this will be due to a fault either with the inverter board or a fault with the screens backlights which would mean the screen needing replaced. Contact your repair centre to have an engineer give you an estimate on the cost of repair.
Oct 24, 2009 | LG 20LS7DC 20 in. LCD TV
While watching my 32 inch lcd hdtv the screen turned dark
Could be some bad caps in the power supply but also the inverter panel.
Aug 04, 2009 | LG 26LG30 26 in. LCD TV
Black screen on a 20ls7d LCD TV
I work at CNN Have had 6 of these monitors go out in as many months. Take out the power supply and change the 2 exploded 680u capacitors. They're being overheated by the underrated MOSFETs on the reverse side of the board. I'm looking for some substitute MOSFETs that handle power better; but replacing the caps will usually fix the problem. Otherwise replace the supply.
Jun 07, 2009 | LG 20LS7DC 20 in. LCD TV
I have an LG 20LS7D flat panel LCD TV. Sound is on but no picture. The problem was intermitent but now nothing but sound. Help
Possibly th emain board needs to be replaced actually you need to check some voltages first but with just a sincere guess signal cba
Sep 26, 2008 | Televison & Video
LG LCD 20LS7D STUCK ON UART DOWNLAD SCREEN
stil have it, i need for parts, let me know
Sep 09, 2008 | Televison & Video
LG 20LS7D
It uses a regular power cord, the kind that you would use for a PC.
Dec 07, 2007 | Olevia LT23HVX 23 in. LCD Television
LG RE-20LA70 20 in. Analog TV LCD Television Logo
602 people viewed this question
Computer Repairing
Computer Repairing
