Question about Canon CanoScan LiDE 70 Flatbed Scanner
Canoscan lide 70
Like many others I receive the following message when trying to scan a document or anything else for that matter -
"Unable to scan - make sure there is enough space on the target disc".
I have over 130G available on my hard drive.Any advice would be much appreciated.
Thank You
    Problem Solver:
Head for the Canoscan Toolbox and click on "Settings".
Under "select folder where temporary files are saved", click on "browser".
Choose where you want the scanned item to be sent and then click 'OK".
This works for me.
Posted on Jun 11, 2008
Can the canoscan lide 70 scan documents to work so they can be edited? Is so how
Yes, but you have to use a special program called an "OCR" (Optical Character Recognizer) which will "read" the document from the scan. A scanner only produces a picture of a document, and it requries special software to "read" that image and make it editable.
The LIDE 70 comes with OMNIPAGE SE (special edition) which will work for simple documents. For more complex documents, you may need to buy the full edition of OMNIPAGE or another OCR package like FineReader. It is also built in fto software like OneNote and Evernote.
The top 5 free OCR tools are here:
Apr 14, 2011 | Canon CanoScan LiDE 70 Flatbed Scanner
When I try to scan with my canonscan lide 70 I get a message "specify the program where the scanned image is transferred"
You just need to point the program to where the scanning program was installed. If you just let it auto-load it should be here: (assuming you loaded the free toolbox software)
C:\Program Files\Canon\CanoScan Toolbox Ver5.0\CSTBox.exe
or just look at where the toolbox is installed by searching for the CSTBox.exe file.
Mar 06, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Using Canoscan Lide 70. When trying to scan receive message "not enough room on target disk" When I reinstall Toolbox it works (for a while, then same repeats).
When you scan a picture, you send it to a "Target" folder which you can set up in your scan options or settings.
At a guess your current destination or target folder is getting to large for the hard drive that its registered on
You've 2 options, clean out the target drive or use the scan options to send your pictures to a new destination with plenty of space.
Mar 05, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Can not scan. keep receiving message "unable to open file".
try to reset the file link (toolbox CS -> settinf -> save -> image file) where the scanned file will be saved.
Apr 16, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Unable to scan.make sure there is enough space on the target disk
Do a "reset".
•Go into the CanoScan toolbox,
•click Settings,
•click the Defaults button on the bottom
•then click OK.
It will take a few seconds to reset and you should be good to go.
Jan 24, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Sep 01, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Grainy and pixelated print
Check to see if you have Grey scale or Black and white
Jul 15, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
LiDE 600DF - Unable to scan
Hi Peter
Have had the same problem, seems to come and go a bit... Quickest & easiest fix is to go to CanoScan toolboox > Settings then press the 'defauls' button at bottom... this sets everything back to factory settings and should fix your problem. Cheers.
Jun 08, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
293 people viewed this question
old marine
old marine
