Question about Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop
Jenn-air CVGX2423 The ignitor won't work on one burner. It will flame with a match.
  • Cymru1 Jun 24, 2008
    I have model CVG2420...Expressions 4 element cook top....not on your list.....but...
    the ignitor worked intermittently for a while but doesn't work at all now.
  • 833 Answers
Is it clicking? No...bad switch. Yes...check ignitor gap on that burner. The gap or the wiring is bad if it doesn't work.
Posted on Jun 15, 2008
Suddenly my Jenn air gas cooktop ignitors (all of them) do not click and spark, the model is CVGX2423B. I suspect it might be spark module fails, is that right?
It sounds like you need a new spark module which controls all of the burners. It is part number W10475147. It costs around $115.00!
Sep 01, 2013 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Some burner allways get sparks on we i turne it on even after flame is produced
Either a grounding problem in the ignitor circuit or ignitor leads have been swapped between burners.
Jun 26, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air Gas stovetop
try to clean the burner and then try it.
Sep 21, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air Expressions cvgx2423b manual request
I have the same model with the same problem. The replacement is simple. Remove the burner cap (no tools needed) Take a large crescent wrench and remove the large center nut holding the burner assembly in place. The ignitor will slide out of the assembly once it is removed. Good luck
Aug 14, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Burner clicks a long time before igniting you can smell the gas
Not sure about what part 1 is about. #2 indicates a failing ignitor gap or a bad gas mix. Get professional assistance.
Jun 13, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
JENN AIRE CVGX2423 COOK TOP
short in the fan wirring.. it is not easiy fix . you need to replace the fan and short wieeing.
Dec 19, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air Gas Cooktop Model CVGX2423
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
One knob does not light and its ignition is not working. The rest of the knobs are working fine. Thanks
You have ignitor issues. If there is a spark on your other burners but not this one it is the wiring, the switch (if the sparking doesn't happen with this burner) or the gap is worn. If these hints don't get you to an answer...get a pro in to look at this.
Dec 31, 2006 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop Logo
402 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
