Question about Sony Cyber-shot DSC-S700 Digital Camera
Cannot get my memory stick to work in my camera. The only memory I have is the 'internal memory' which is good for about one minute and possibly 10 photos. How do I get the memory stick of 1GB to start remembering?
  • 10,594 Answers
Did you formatted memory stick in camera?
Insert memory stick in camera and Format it by going into setup menu, you will see Format option and this will solve the issue.
If problem still not solved and camera gives memory stick error then try another memory stick in camera, you can use up to 2GB memory stick in this camera.
Thanks.
Posted on Oct 24, 2010
SOURCE:
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
Is it possible to transfer the photos I took on my Cybershot camera onto my memory stick?
To copy the images from the Internal Memory of the Camera to the Memory Stick select the COPY option from the Memory Stick Tool Menu of the Camera to OK.
To select the Copy option, press MENU-->SETUP-->MEMORY STICK TOOL-->COPY-->OK.
The copy option will copy all the images in the Internal Memory to the Memory Stick in the Camera.
Thanks for using FixYa
KenSolutions
Dec 06, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Dec 04, 2010 | Sony Cyber-shot DSC-T2 Digital Camera
Hi I have a sony cyber shot camera when i tried to ON it The memory stick error appears saying " INSERT MEMERY STICK" inspite of memery stick is inserted also i get this error.And when i tried to format it...
The Reinsert Memory Stick error message appears when the inserted Memory Stick is corrupted or not in a correct Format. This issue can be resolved by trying the steps mentioned below:
  • Remove and re-insert the Memory Stick in the Camera.
  • Check if the inserted Memory Stick is compatible with the Camera.
  • Format the Memory Stick in the Camera. Do not Format the Memory Stick in the Computer, as this will damage the Memory Stick being used in the Camera. The Camera will not detect the Memory Stick again, if it is formatted in the Camera.
  • Clean the terminals of the Memory Stick by using a soft dry cloth.
  • Remove the Memory Stick from the Camera and check if the Internal Memory is working fine.
You may also try power resetting the Camera. Power resetting can be done by removing the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cameras
NO space on internal memory
Hi. Actually you justneed to delete or transfer some pictures on the internal memory to your memory stick or you could remove first the memory stick and plugin you digital camera to your computer and copy all the pictures or videos on the internal memory of your digital camera.
Jun 04, 2010 | Sony Cyber-shot DSC-H50 Digital Camera
My cybershot w120 keeps saying no space on internal memory when i have a new memory card in it which is empty. This happened with my last card so now i am thinkng its more a camera problem rather than the...
in your settings is it set to "shoot without card"? this could cause the camera to not use the memory card installed and rely on internal memory which is limited
Aug 26, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
How do I retrieve photos from my built in memory storage if I don't have a camera to computer hook up wires?
Put memory stick in camera, power up and press Menu on camera, select Copy option and press OK
That will copy photos from internal memory to memory stick.
Jun 19, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Cybershot DSCw80 doesn't read memory stick
Have you tried a different/new memory stick other then the one it came with? It is possible that one is no longer working. Once you try that I can assist you further. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
Feb 27, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Dsc-s700 format error
If you have a computer with a memory card reader that takes the stick. insert it into the computer and goto my computer find the memory stick drive letter and format it their then retry the stick in the camera. also try to go into the cameras menu and try formatting it their if you cannot format the stick it is very possible it is bad.
Mar 21, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Memory stick error
Try using another memory stick, or insert a confirmed good memory stick, if OK, the memory stick is defective, if the same error, try pressing reset at the back of camera, a small hole beside the the DC jack. if OK, then fine, if still the same, camera needs repair. thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
