Question about Dryers
How do you move the dryer door so that it opens form the left instead of the right
  • 3,074 Answers
Http://www.ehow.com/how_5968181_change-dryer-door-left-right.html
Posted on Oct 24, 2010
6ya staff
SOURCE:
Can I change the door to open left to right instead of right to left
yes,Tim:
http://www.ehow.com/search.html?q=reverse+dryer+door
May 29, 2011 | Kenmore HE5 Electric Dryer
How do you change the dryer door from a left to right opening to a right to left opening. Thid is a series 90 kenmore
Open the dryer door. There should be approximately three screws that hold the hinges on there on the right side (as you said yours currently is a left to right opening). Remove the screws that hold the door on. As you hold the dryer door removed from the dryer, turn it counter clockwise so that the handle is now on the opposite side. Lay it on the floor. Now, remove the screw hole covers from the opposite side of the dryer opening ( the left side) (these can be removed with a fingernail or a thin flat tipped screw driver to pry them out). This will expose the screw holes on the opposite (left)side of the dryer. Take the removed covers and place them in the original screw holes on the right side. Now simply reinstall the door hinges in the newly exposed screw holes on the left side. This will only work if your dryer is designed to have both types of openings. Good Luck!
Feb 27, 2010 | Kenmore 659 Electric Dryer
Is it possible to change the dryer door that will open from right to left instead from left to right
Yes ,most dryers will allow this. although you will have to remove door to do it. You should see mount holes on the other side of door sometimes have plugs to remove or srews. The hinges on the door will have to be moved to opposite side. Once again should see mount holes. The whole operation takes a matter of minutes once you see how it is done. Hope this helps
Jul 29, 2009 | Whirlpool WGD5300S Dryer
Is door reversible on duet model GHW9100LW1
The technician informed that we cannot reverse the door on the washer.
Apr 09, 2009 | Whirlpool Washing Machines
Washer door opens with hinges on the left
Don't you think it would really boost sales if you did make a washer that the front loader door could open left to right . For homes that have very limited laundry room. and no way to switch.
Dec 28, 2008 | LG WM-2277HW Front Load Washer
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Dec 28, 2008 | LG Washing Machines
How do you change the door on a Maytag 200 dryer to open right to left instead of left to right? Is that something that a homeowner can do?
Please specify the numbers on to machine data plate (serial, part #, etc.).
Some models do not have that option, but most Maytags do.
Aug 12, 2008 | Maytag Dryers
Can I change the way the door opens?
no you are stuck with the fact how they were buld.unless you want to mover the doorlock and all wiring and the hinge.
also have to make a hole for the doorlock.
I would not advice this.
May 02, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
jimorris77
