Question about Toshiba 44NHM84 TV
I have a Toshiba model 44NHM84 DLP projection TV that will either attempt to power on but then shuts down or when it has powered on there is good sound but no picture.
    Brigadier General:
  • 8,909 Answers
You will probably find, cahnging the lamp and resetting the timer will fix this problem.
Contact Toshiba for more information if you need to.
Toshiba.com
Posted on Oct 24, 2010
  • collins250 Dec 17, 2010
    how to reset timer
  • specialistel Dec 18, 2010
    The instruction for that, as far as I am aware, atre included with the new lamp. Any problems, contact Toshiba.com for clarification.
    Hope that helps.
SOURCE:
We have a red light flashing on the front of the tv.It shut off and we don't know how to turn it back on.
A red flahing light is sometimes a Standby Mode. Does the power button on the remote turn it on.Sometimes the remote has multi funtions and you need to select TV for it to work.Try using the Power Button on the TV.Good Luck.
Jul 29, 2011 | Toshiba 44NHM84 TV
My Toshiba 44NHM84 does not power up. The
It is possible the ballast has failed
Mar 04, 2010 | Toshiba 44NHM84 TV
How do I reset the DLP lamp timer on my Toshiba 44NHM84 TV?
Hi,One way to reset lamp timer is to unplug tv wait 5 min and plug it back again.
Jan 05, 2010 | Toshiba 65HM167 65" Projection Television
I have a Toshiba DLP Projection TV model # 44N HM84 made in October 2004. When we turn it on the green light blinks about sis or seven times then turns red. The TV doesn't come on. Any ideas? thanks in...
It is an error code. Count the flashes and then re-post asking what the amount of flashes means and how to repair it. Make sure you post make and model of TV.
Dec 03, 2009 | Toshiba 44NHM84 44" TV
How to replace Power Supply in Toshiba 44NHM84 44" TV
Since this is a DLP type set, there is a lamp and ballast involved. When the set shuts down, are there any indicator lights on the front? If so, check the owner's manual for an explanation of their meaning. Typically, the lamp can cause this or the ballast. If either of those are the problem, usually the lights on the front panel will indicate it.
Keep us posted.
Dan
Sep 21, 2008 | Toshiba 44NHM84 44" TV
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
Shadow down right side of screen on a toshiba 44NHM84 44" DLP television
shadows at the bottom of the screen sound like moisture that was "wicked up" between the screen layers and dryed out leaving a stain. DO NOT get these screens wet, use nothing but a damp soft cloth; just a few drops of water running down the screen can cause a fairly large stain. Some people have suggested that they may be professionally cleaned, but the risk of damage is too great on the user level.
Nov 12, 2006 | Toshiba 44NHM84 44" TV
Open Questions:
Toshiba 44NHM84 TV Logo
396 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
