Question about Sceptre X20WC (Black) LCD Monitor
I turn on the computer on and it the monitor turns on then off.
    Guru:
  • 2,178 Answers
Try another monitor - if it does does same thing, your graphics card may be the problem. If not, then it's the monitor.
Posted on Oct 24, 2010
SOURCE:
AL 1706 troubleshouting monitor wont turn on green
If your monitor shows a yellow light and it won't turn green, the problem most likely lies with the computer. If your computer is not sending a signal to the monitor, then you have a computer problem. One way to test this is to turn the monitor off and the computer off, too.
Turn the monitor on and if it is working, it should display a message telling you that there is no signal. If you see that message, you can assume the monitor is working. If you do see it, now turn on the computer and see if the message changes.
If you turn the monitor on and you get no message, you can assume the problem lies with the monitor itself.
If you have access to another monitor, hook that one up to test the computer output.
You can now either get the monitor fixed or the computer fixed, depending on which one is bad.
May 31, 2011 | Acer Computers & Internet
My monitor keeps giving me a no signal message after i turn on my computer
  1. make sure that the video cable is properly connected between the monitor and computer
  2. change the video cable
  3. do a monitor selftest
  • turn off the monitor
  • disconnect it from the power outlet
  • disconnect it from the computer
  • turn on the monitor without the video cable
if you see the monitor information (a box with RGB white colors, the monitor is working)
  • problem might be the cable, video input port of the monitor or the video output port of the computer
Apr 10, 2010 | Acer AL1916W 19" LCD Monitor
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
My Computer turns on but my monitor doesn't. HELP !
boot up the computer in safe mode and see if the monitor works on a really low resolution. if it does maybe the resolution of the computer was unsupported by the monitor. up the resolution gradually or find out the optimal resolution for the screen
Oct 02, 2017 | Acer AL1714MS (Silver) 17" LCD Monitor
We leave our computer turned on at night but we turn off the monitor. The last two weeks when we have turned on our monitor in the morning it will show the desktop but when we move the mouse the monitor...
Yes. Do not turn the monitor off by its power switch, let the computer do the work for you. Alot of times when people use the power switch to turn off the monitor, the computer sees that all of a sudden the monitor has been disconnected from the pc. when that happens the pc sees it as a device beimg unplugged and removes that certain device from the pc's list of things that should be connected, and when you turn it back on the pc sees it again and starts loading drivers for that new part(monitor)
Sep 21, 2009 | AOC LM729 17" LCD Monitor
Monitor comes up white on computer start up
see if you have bent pins on cable.
Aug 19, 2009 | X2Gen MW22U Monitor
My compaq presario MV730i color monitor will turn on from hibernation mode and then turn off when the computer is turned on. Any ideas what I can do to correct this issue? Can not afford new monitor.
I heated the monitor up with a heating blanket and a space heater. then reconnected to the computer. turned computer on and the monitor worked.
Mar 06, 2009 | Compaq Computers & Internet
After turning off the monitor, can not be turned on?
We need a little more information. After you turn it off, is the computer off, also? If you turn on the monitor (does it have a yellow or green light), and then turn on the computer, do you see anything on the monitor.
Is the monitor plugged into the wall and is the power cord tightly plugged into the back of the monitor (sometimes comes loose).
If the monitor will not turn on at all after you've checked the above things, then it has gone bad on you.
If you get a light on it and you have turned on the computer but there is no display, it is very possibly the video card.
Of course, this all assumes that the computer is actually starting up.
Feb 19, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Monitor
-Turn off both computer and monitor
-unplug monitor from computer(still plugged into power supply)
-turn on computer and monitor(monitor is still unplugged)
-After computer is on for about 30 sec. plug monitor into computer
-turn off both monitor and computer(now connected together)
-turn on monitor then computer and should be good to go!!!
Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
Open Questions:
Outlook MAil Tollfree {1=855={536}{5666}#[email protected] PHoNe NuMbER IOWA This SbCgLoBaL MaiLUSA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiLUSA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the SbCgLoBaL MaiLUSA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiLUSA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiLUSA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact SbCgLoBaL MaiLUSA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiLUSA Calling SbCgLoBaL MaiLUSA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiLUSA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiLUSA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiLUSA's phone numbers against each other. Contacting SbCgLoBaL MaiLUSA in General While I855%536%5666 is SbCgLoBaL MaiLUSA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiLUSA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Oct 16, 2019 | Best Computers & Internet
Arlo tEcH sUpPoRt pHoNe {@#}{\1845481*1722*] nUmBeR KBl USA Netgear Arlo Security Camera Tech support Number EMAIL +[{1\845:-481-1722*}]Wireless Repair service center to resolve all Netgear Arlo Security Camera customer service phone Number products. Netgear Arlo Security Camera is an American multinational company which was founded by Michael Netgear Arlo Security Camera using its company headquarters in Round Rock, United States of America. Contact Netgear Arlo Security Camera for Setup & Installation Netgear Arlo Security Camera Setup Free & Installation Netgear Arlo Security Camera TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Netgear Arlo Security Camera Connect, Netgear Arlo Security Camera TECH Free Phone Number you'll be searching out Netgear Arlo Security Camera Connect setup as well. So, here we're with all cthe setup process and for your to Netgear Arlo Security Camera Connect. Get Netgear Arlo Security Camera Setup Instant Free Netgear Arlo Security Camera TECH FREE Phone Number Usually, the setup TECH nique takes a number of time. One TECH nique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Netgear Arlo Security Camera Connect setup for Windows and for Mac. So, right here we go vikki TALATUM
Oct 16, 2019 | NetGear Computers & Internet
See all Sceptre X20WC (Black) LCD Monitor Questions
Sceptre X20WC (Black) LCD Monitor Logo
50 people viewed this question
Top Sceptre Computers & Internet Experts
Ekse
Ben Slimene Aymen
Ben Slimene Aymen
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
