Question about Whirlpool Refrigerators
Hi,my whirlpool refrigeror stoped working and i found that the circuit board is bad.How can i get a replacement? The model # is WB 100. The circuit board is at the back near the compressor.
  • Whirlpool Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Oct 25, 2010
SOURCE:
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
Oct 03, 2015 | Whirlpool Dishwashers
Whirlpool Accubake control panel not working. Model YGY399LXUS03.
I found this on a repair site for your model: The oven control board has relays that send voltage to the bake and broil circuits according to the user settings and sensor input. If the control board is defective, it may not send voltage to the heating components. However, this is rarely the case. Before replacing the control board, first test all of the heating components. If you determine that all of the heating components are working properly, replace the oven control board. Since it's not easy to test the oven control board, you will have to replace the control board if you suspect it is defective.
Sep 16, 2015 | Whirlpool Kitchen Ranges
I have a jacuzzi aero it will not heat and relay #3 chatters
This chattering means you have a bad relay on your circuit board. It will need to be replaced or you will need to replace the complete circuit board. Since you have tried to replace the relay i would suggest a new circuit board.
RodUS Parts Center888-521-6183
Jan 14, 2013 | Jacuzzi Home
It is a Kenmore Coldspot (Whirlpool) side by side model # 106.57024601 a repairman replaced the ice maker circuit board which had shorted from washing the outside of freezer door with spray cleaner....
its a tuff call but i think if the board has been replace and the motor runs then ck the touch panel that selects reg or crushed . . and if it is the board that has been replaced re ck all the connections .. mm
Sep 24, 2010 | Whirlpool Refrigerators
Refrigerator works fine until the door is opened. The unit shuts down when the door is opened and it will not come back on when the door is shut, Recycing the circuit breaker will cause the unit ti start...
From your description , the control board is bad . This board is located behind the refrig , on the left side at the bottom , inside a white plastic case . Only 2 screws hold this case on , and it snaps apart to reveal the board . It costs about $ 80 and is easily replaceable . Take your complete model number with you so you get the correct part . I determine this due to when the door is opened and the refrig section lights do NOT come on ( the temp control lights also ) , this is a bad board 100% of the time .
Sep 03, 2010 | Whirlpool Refrigerators
Light and temperator display out on refridgerator side
Had the same problem. Someone on this board told me about this circuit board. I found one online for $73 and replaced it myself.
Part Number: AP4334000
Made by WHIRLPOOL
Check out this website:http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136804&diagram_id=935861#d935861
Jan 03, 2010 | Whirlpool GS5SHAXN Side by Side...
Dim light on oven display w30400b jennair
The circuit board is for the display/touch panel. It is mounted on the back of the display panel itself and connected to the other circuit boards by two multipin connectors. When you remove the display panel (3 screws on top, 4 on the bottom) you will be able to GENTLY detach those connectors. They are low voltage and may be handled safety even when the oven is powered, but I agree that turning off the oven circuit breaker is good practice.
To remove the circuit board, GENTLY release the two black plastic tabs; the solder pads are underneath. I too used a 100 mf capacitor because no local supplier had a 68 mf hi-temp. Observe polarity; the (-) lead goes towards the center of the board (away from the edge connector.)
BTW, I had exactly the same symptoms (display goes dim, then goes out altogether.)
Jan 16, 2009 | Jenn-Air W30400P Stainless Steel Electric...
Hi i have a heavy duty whirl pool electric tumble dryer. It was just running and i opened the door to remove some towels and then shut the door and pressed start. it started for a moment and then stoped...
If unit starts up after a while then your motor is bad and needs replacing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Whirlpool Dryers
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Oct 13, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
54 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
