Question about Compaq MS Windows 2000 Datacenter Server for PC
HELP I have a compaq it was gave to me today and it shows on the screen operation system not found on any devices
    Genius:
  • 2,785 Answers
You have to install the operating system from the cd
Posted on Jun 10, 2008
Operating system not found
there is problem with your hard disk. your hard disk wire may be loose. try to remove and refix all sata wires of your hard disk. "operating system not found" message may be coming because you may have not installed any os (windows, linux or mac) in your notebook. try to install operating to system to fix this. there may also be proble with your hard disk, your hard disk may be dead. if your notebook is showing message "operating system not found" without any reason then you may have put your notebook in high magnetic field area. due to high magnetic field, sometimes hard disk's are formatted automatically.
Apr 10, 2013 | Samsung N150 Notebook
Opertaing system not found
Your hard drive may be faulty, this is why the Windows operating system not found.
Go into the BIOS and see if the hard drive is detected, if not reseat the hard drive and boot up again.
If the Windows operating system not found then most likely the hard drive is faulty and to get the Notebook working again, replace the hard drive, install Windows on the new hard drive plus the Compaq Presario 1692 device drivers and your programs.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Jul 14, 2011 | Compaq Presario 1692 Notebook
HP Compaq notebook will not boot up. It seems to start and immediately shuts down. I am unable to turn it off without removing the battery or disconnecting the power supply. This happened before and...
information. hpweb_1-2_plus.gifhpweb_1-2_minus.gifRun a Microsoft system restore
    hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows XP Click Start , All Programs , Accessories , System Tools , System Restore . Select a windows restore point from a time when the computer operated properly, and then restart the computer. hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows Vista or Windows 7 Click Start, type restore in the search field, and select System Restore from the list. Select a windows restore point from a time when the computer operated properly, and then restart the computer.
If the computer does not boot into Windows, you can restore the computer settings to an earlier point in time. Turn on the power and press f8 . On the Windows Advanced Boot Option screen, select Safe Mode and boot into Windows. hpweb_1-2_plus.gifhpweb_1-2_minus.gifUpdate Windows, the BIOS, and HP device drivers
Nov 11, 2010 | HP Compaq nx9600 Notebook
Graphic problem
Try to reinstall you'r graphic driver. If you don't remember what driver you need, then let a computer program search for it (f.eks Driver Detective, Driver Genius, Driver Agent, etc....)
Jul 29, 2009 | Compaq Computers & Internet
My Compaq Presario F700 dropped approximately 2 feet to the floor from on top of a suitcase at the airport. It was in a case, but not a thickly padded one. When I tried to use the laptop after the fall,...
Try reseating the hard drive and the RAM modules, the fall may have slightly loosen these components.
The error message "Operating System not found" means the laptop could not find the hard disk, this problem could be the hard drive needs reseating, a faulty hard drive (they don't like being dropped), or a faulty disk controller.
Apr 28, 2009 | Compaq Presario 1692 Notebook
CRX880A rom on compaq c500 notebook not working
The disk spin motor either gave out or became disconnected. Repair or replacement of the drive might be your only options.
Feb 18, 2009 | Microsoft Windows Vista Ultimate Edition
Problem with Audio Driver instalatin of compaq V3000.
Allow it to auto install the driver for the hardware. It's telling you that it requires a driver, either it is corrupted missing deleted, or any of a dozen reasons, two things that are quick fixes prior to spending a couple hours troubleshooting the machine. I assume it worked prior to today, so just do a restore to an earlier time, if the it for some reason doesn't install the proper driver. You can try installing form a disk, if you have the original disk from the laptops motherboard. other wise, go to Start, programs, accessories, system tools, system restore, and allow it to restore itself to a date when all was working properly
Jan 23, 2009 | Compaq Presario Notebook
Audio device on high definition audio bus
Was your operating system windows vista? cause some drivers do not detect if the operating system is not compatible with your laptop, have it check.
Thanks
Nov 22, 2008 | Compaq Presario 700 470024-192 Notebook
Booting system does not work
try to reload the operating system
May 04, 2008 | Compaq Presario M2000 Notebook
Acer Aspire 4720Z
Hey there neha patne, based on the info given, my best guess is that your boot sequence is not placing your harddrive as your primary boot device. While you are in the setup screen (via F2), locate the boot sequence line and enter. Change setting to place harddrive as primary boot device, disabling the other options and not leaving it as an auto-detect setting. Save changes and reboot. Also please ensure there are no media in the drives or unnecessary peripherals plugged in while booting up. I hope this helps. Good Luck.
Jan 28, 2008 | IBM ThinkPad T41 Notebook
Compaq MS Windows 2000 Datacenter Server for PC Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
