Question about ViewSonic VA721 17" LCD Monitor
How to resolve 'no analog signal on viewsonic monitor'?
  • 11,361 Answers
Try it with another PC and check the VGA cable to make sure it is not the monitor problem. If it still does not wotk, then it may have problem like bad caps as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 24, 2010
SOURCE:
Why can't I get a signal from my Viewsonic monitor VS13860?
VA2448m-LED monitor. Ensure your cables are connected securely and the input source is correctly selected. Then make sure you are sending a valid timing resolution mode to the monitor. If this fails, please call ViewSonic technical support to help resolve your issue.
Oct 01, 2014 | ViewSonic Computers & Internet
What do i do when it comes on and shows analog then goes blank ?
Are you using the analog input or another? If using another input instead, then press the 2 key. It will switch to another input as the source signal. If you still experience trouble, please contact ViewSonic technical support for assistance.
May 03, 2014 | ViewSonic VG1930WM LCD Monitor
What does no signal analog mean
It means your monitor has both analog and digital inputs and it is trying to use the analog one and not finding any signal. What kind of a connecting cable are you using, blue ends with 15 pins, or white ends with lots of pins and one long wide one on one end?
Feb 14, 2011 | ViewSonic VG930m LCD Monitor
I cannot get desktop for internet Th screen say no signal analog. I only use it to surf the net the small light lights up
Are you using the DVI (DIGITAL) or the VGA (ANALOG) to connect to the PC? You may also have the caps that are going bad, see example here, you should check them out before too late.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 11, 2010 | ViewSonic VX2235wm LCD Monitor
My viewsonic mo9nitor says analog not digital on
To clarify, you know that analog is referring to the VGA 15 pin video input, and digital is referring to the DVI video input, right? You can't have the digital video unless you use the DVI input, which requires a DVI output from your computer (and a DVI cord of course).
If you already knew this and you mean that it won't switch over to your DVI, then there could be several problems. Most of them being with your DVI signal source (computer). Try booting the PC with ONLY the DVI cord attached between the PC and the monitor. If you have a VGA cord plugged into either, UNPLUG IT FROM BOTH ENDS.
Dec 05, 2009 | ViewSonic Computers & Internet
No analog signal
Sounds like the graphics card is gone belly up. Try the monitor with another pc or just replace the graphics card.
Hope this helps
Jun 12, 2009 | ViewSonic VX2235WM Monitor
No signal analog
Press the front screen button that has an arrow. It will be switching from analog to digital and digital to analog if you press it again.
Mar 12, 2008 | ViewSonic VX2235WM Monitor
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
ViewSonic VA721 17" LCD Monitor Logo
154 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
