Question about GE Security Simon 3 Wireless Home Security System
Simon XT Low battery..constant beeps. Is the battery user replaceable? Where can I purchase one.?
SOURCE:
  • 3 Answers
SOURCE: battery low sensor failure on Wireless Simon ADT
the sensor seems to be malifunctioning and will have to be replaced
Posted on Sep 28, 2009
  • 74 Answers
SOURCE: GE Simon XT how do I reset the code
You neet to reset the system to factory defaults. Contact me and I can go through it for you.
AlarmProfessor.net
Posted on Aug 23, 2010
  • 6 Answers
SOURCE: Simon 3: A remote window sensor downstairs creates a constant Low Battery beep/message.
you have to run a sensor test so the system will recoginize the new battery, open keypad cover type in your code press test till it says "sensor test" once it runs through all points press done, now reset your panel disarm code disarm
Posted on Oct 17, 2008
SOURCE: Simon 3 "System Low Battery" after 3 years use
I have the same Security System the same problem, with the 2 beeps every couple of hours .
The Control Center called and said the battery on the door connector was low and that was the cause of the beeps not the entire system, I replaced with 2 triple A batteries and no more beeps.
Pauline
Posted on Nov 08, 2008
  • 31 Answers
SOURCE: Low Battery warning on Simon 3 even when I changed it out
temperature affects batteries. if the batteries on the window sensors have been in use for some time it is probably time to change them. Alarm batteries are only expected to last 3 to 5 years with moderate use. If you have close neighbors or live in an apartment complex then false reads could be a factor.
Posted on Aug 24, 2009
Hello. there seems to be a beeping noise coming from the control box itself and it says to check status, but i'm afraid to push anything. thank you
Troubleshooting a GE Simon XT: Clear Errors and Alerts ...
? 3:06
https://www.youtube.com/watch?v=AtOCuthlsTo
Oct 3, 2011 - Uploaded by LiveWatch Security
Troubleshooting a GE Simon XT: Clear Errors and Alerts -Wireless Home Security ... Many times the Simon XT panel willbeep to indicate there is something ... How do you turn off the warning beep when you turn on alarm? I find it very useless and annoying. Can't seem to find a way to turn that feature off.
My Simon XT is beeping every 4 hours. How can I stop it ...
help.livewatch.com/.../20399861-My-Simon-XT-is-beeping-every-4-ho...
Aug 28, 2011 - If your panel has been beeping throughout the day and you want to turn off ... Scroll down on the Simon XT until you see "System Programming".Missing: control ‎hello ‎control ‎box
Jan 11, 2016 | GE Security Simon Xt Wireless Control...
Simon XT "system low battery"
IT might be testing ok, but you need to load test it. It could be the charging circuit but in most cases the battery will show a surface charge that is ok for a short period of time.
Feb 10, 2014 | GE Security Simon Xt Wireless Control...
System says low battery ... how do I open it to replace batteries...very confusing!
There are two tabs (and possibly a screw) on the top of the Simon XT panel. Remove srew (if installed) and press the two tabs, pulling forward. Front part of panel is hinged and will rock forward. Battery is located behind front half. It is a 6 volt 1.2 Amp Hour lead acid battery.
You must completely downpower the Simon XT (wall plug in and battery) then replace with new battery first, then reconnect wall power. Close the front panel and snap it closedand replace the screw (if it was installed).You will need to set the time on the panel, following the instructions in the users manual.
Jan 05, 2011 | GE Security Simon Xt Wireless Control...
I have a GE Simon XT. I arm the system. When I return several hours later, the front door doesn't beep when I open it. I have to close/open it again to register. Front door is Sensor 1, Group 10. What...
Can I assume it is a wireless contact we are talking about?
1.) Low battery in tansmitter. Does your keypad display a low battery trouble? If so, ensure you put system in test before replacing battery as not to generate a tamper alarm when opening contact.
2.) Relay in transmitter is sticking. Replace wireless contact.
Stewart
May 26, 2010 | GE Security Simon 3 Wireless Home Security...
Battery low sensor failure on Wireless Simon ADT
Sep 20, 2009 | GE Security Simon 3 Wireless Home Security...
How do I replace the battery in my Simon XT security system
Here is a very easy to follow video tutorial that may help you.
You can get a replacement battery from here
Simon XT GE Security Security Alarm Battery 6V 1 2AH
Mar 08, 2009 | GE Home Security
it should be a 6 volt, 1.3 amp hour battery. you can get them at batteries plus. best bet is to take the old one with you to the store to ensure that it fits.
Jun 14, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
1,895 people viewed this question
Top GE Home Security Experts
Bill
Level 1 Expert
Anthony Ward
Anthony Ward
Ekse
Are you a GE Home Security Expert? Answer questions, earn points and help others
