Question about Nokia N73 Cellular Phone
Sagem my v-56
Pin code
    President:
  • 1,257 Answers
Complete information :
The SIM card protects your subscription and not the phone from unauthorised users. If you change SIM cards you can still use your phone with a new SIM card. Most SIM cards are blocked at the time of purchase. If your SIM card lock is on you have to enter your PIN (Personal Identity Card) every time you turn on the phone.
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
Note:
card (Personal Unblocking Key). Your PIN and PUK is supplied by your service provider. You can edit your PIN and select a new four to eight digit number
  • If the Message Codes do not match appears when you edit your PIN you entered the new PIN incorrectly.
  • If the message Wrong PIN followed by Old PIN appears then it means that you have entered the old PIN incorrectly.
To unblock your SIM card:
  1. When PIN Blocked appears enter your PUK > OK
  2. Enter a new four to eight PIN > OK
  3. Re-enter the new PIN to confirm > OK
To edit your PIN:
  1. > Settings > the General tab > Security > Locks > SIM Protection > Change PIN
  2. Enter your PIN > OK
  3. Enter a new four to eight digit PIN to confirm > OK
To turn the SIM card On /Off
  1. > Settings > the General tab > Security > Locks > SIM Protection > Protection and select On or Off
Posted on Jun 24, 2008
    Guru:
  • 458 Answers
Your pin code is found on your sim, it is only your network provider who can provide you witth your pin code. contact them and they will give it to you. if your pin is blocked, you need a PUK, they will provide it to you
Posted on Jun 08, 2008
Unlock codes for Sagem my401x, 358199002315313, sim 3V, D2005, 252427706/my401x
Dear Mr Please try it:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Dec 04, 2012 | Sagem my401x Cellular Phone
Network unlock pin
What is Your correct My 700x model.Please specify it..There are two models available...Choose your model correctly in the list and Unlock it...You can get the NETWORK UNLOCK PIN for Sagem MY 700X model Phone at
Onlinegsmunlock.com/sagem/rs7wp8/ and Unlock it easily..
Oct 12, 2012 | Sagem my700X Cellular Phone
Sagem myc4-2 unlock
Sep 30, 2012 | Sagem Cell Phones
I need to unlock sagem myc2-3 mobile phone
Hi visit Prounlocking.com to unlock your Sagem myc-2-3 mobile from network lock .Here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Aug 30, 2012 | Sagem Cell Phones
I've had a Sagem myV-56 for about 6 years but never used the pin number and don't have a record of it. How do I know what the pin number is for my phone so I can reset it and make use of the security...
there are two pins one is given by the service provider thats puk number ull have to call ur operator for that other is phone pin which locks the phone and that has to be either of 1111, 0000, 1234.
Jan 20, 2011 | Sagem Cell Phones
My phone sagem can open.insert sim out SIM LOCKED.WHY I CAN DO
Contact your wireless carrier to obtain your PUK code (Pin Unblocking Key- A code that required to unlock the sim once a Pin had been entered incorrectly too many times) Keep in mind that if the PUK code is entered incorrectly10 times, your sim will be permantly disabled and you will have to purchase a new sim
Hope This Helps!
William
Sep 22, 2010 | Cell Phones
Need to find receiver code
Your question is listed under Sagem PVR6280 so I'll assume that'swhat you have. What follows also applies to the 6240, 6200 and 6200t.
Like on many other makes of receiver the unit uses a PIN code protection system to prevent unauthorised viewing and also to prevent unauthorised tampering of the system settings. If you have not previously set a PIN code then Sagem typically use default codes of 1111, 1234 or 0000. If this does not work then there may be a jumper switch inside the box on the main circuit board which willclear whatever code has been previously set back to the default code.Note that later revisions to these units do not have the reset switchand can only have the PIN reset via a manufacturer firmware flash: getting this done maycost more than the box is worth as it has to go back to Sagem.
Open thebox at your own risk and ensure that you physically disconnect the boxfrom the mains and use an anti-static mat or an anti-static wrist-strap.From memory, I think that when the jumper has been altered the box needsto be briefly re-powered and then turned off to allow the jumper to bereset back as it was.
If your box is a Sagem 6240/6260 then DONOT update it yet as these models are known to be incompatible with theupdate and will lose some functionality afterwards. The official adviceis to contact Sagem directly on 0845 0900 316 to see if they have a fixyet, but the number is clearly going to be ridiculously busy for at least a couple of weeks as thousands of their boxes are affected.
Cut and paste the web address below into your browser for the official line:-
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
I hope that you have found my answer to be useful and ask in return only that you take a moment to rate my answer.
Oct 04, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Sagem 101x sim lock code
plz tell how to unlock my sagem 101x sim lock code
Feb 24, 2008 | Sagem my100X Cellular Phone
Nokia N73 Cellular Phone Logo
82 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
