Question about E-Machines eMachines Desktop PC
My kids e-machine pc will boot up it just comes on and sounds like the fan is working overtime and the screen is blank
  • 707 Answers
Check the RAM modules and make sure they're sell seated in their slots. If that doesn't work you might try this.
Bring up task manager Ctrl+Alt+Delete and click the applications tab
Click on "New Task"
type in explorer.exe and click okay.
If it boots up run malwarebytes available here www.malwarebytes.org
run full scan and delete anything it catches.
Good luck
Posted on Oct 29, 2010
SOURCE:
Power light comes on, but will not boot, also fan doesen't come o
Without looking at it sounds like a dead motherboard. You should be able to take it to a local shop and have then check it out for about $35-$50
Dec 29, 2009 | ASUS F5R-AP038A Notebook
Had trouble booting the computer over time. Sometimes power light would come on and nothing else. By unplugging, waiting 15sec it would power up. Over time this stopped working. Eventually power light...
Time to look for a new computer. That and take out your hard drive to copy your files over.
Sounds like motherboard problem. Probably not worth repair.
I've got an HP desktop with similar problems. It turned on one day just fine. The next day not. I don't even get the boot up screens. Disconnecting Hard Drive and CD/DVD components do not help. I should at least get some BIOS POST beeps and a Hard Drive Not Found or such. I do not. On occassion it will boot to a blank screen with white cursor in upper left. Most the time no screen at all. On rare occassion it comes right on and boots Windows. I guess it could be the power switch ... but I doubt that.
Nov 22, 2009 | E-Machines eMachines Desktop PC
I have got a Toshiba Equium A200 series that won't bootup
if the fan is not running continuously then its the fan ans board problem.because the board is getting hot and fan is not running so the board is getting overheated and the machine is nor working.and if the power light is ON and fan is running but only the screen is black/blank then its the problem of inverterboard.the cost of new board is $25 get it replaced fromn near by laptop repair center. thanks.
Aug 30, 2009 | Computers & Internet
Acer Aspire M1100 desktop will not boot or respond
sounds like a motherboard or HD problem, If you can try the HD in a different pc to see if it can be recognize, also don't forget to setup you pc to boot the HD first.
Jul 03, 2009 | Acer Computers & Internet
Power on emachine T6420 and moniter is blank. The moniter soon loses contact with the computer. The fan run and power is OK there is no beep code.
If you mean after the computer performs the self test the screen goes blank and stays blank, eventually turning off you are having a hard drive problem. When the computer boots you should see an E-Machines logo and/or a self test on the screen. That is done by the motherboard as part of every boot up. After that the motherboard passes control to your boot device and loads your operating system. If your computer stops booting at that point, your boot device is not working properly. That could be caused by many things - virus, hardware failure, power outage. If you really mean you see nothing at all on the screen when you press the power button your computer simply is not working at all. Open the case, blow all the dust out of it and reseat all components you can, then try again.
Jun 05, 2009 | E-Machines eMachines Desktop PC
Emachines t2899 will come on and fans run but screen is still blank
Actually, the monitor is fine. The problem is that the computer isn't booting. The power comes on and the fans spin, but the system board isn't starting. Try reseating the memory modules in their sockets and clearing the CMOS memory using the jumper on the system board. If the problem continues, try another power supply. Finally you may need to replace the system board.
May 13, 2009 | E-Machines T2899 PC Desktop
Screen won't appear upon start up and I get 3 beeps but no screen
3 beeps POST code (power on self test) means RAM problem.
Reseat the RAM module/s and boot up your computer.
If you have two RAM modules, remove them both and insert one at a time to test them, to determine which module is faulty.
If it still doesn't work then replace the RAM module/s
Apr 02, 2009 | Everex StepNote NC1500 Notebook
Start laptop up, sounds like its working but screen is blank
You should take it to a professional that can look inside and see if any components came loose.
Dec 29, 2008 | Acer Aspire 9300 Notebook
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
