Question about Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
What are the buttons on the shv66a03uc labels worn off
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
While I don't have the SHV66, I do have the SHV68 which is identical, the SHV66 actually replace the production of the SHV68.
This should provides you with the program cycles you need to identify.
i.e.
I do have the image of the SHV66, but it appears too small to be much use to read the letters of cycles...but as I said the one above is the same.
Thanks for choosing FixYa and good luck.
Let me know if you require further assistance and please take a moment to rate the info I provided for you here today.
Regards,
Macmarkus :)
Posted on Oct 24, 2010
Testimonial: "wow!!!! very useful and QUICK response. Thanks so much!!! barry"
SOURCE:
My Yamaha rxa720 remote won’t power on or off the unit. All other remote buttons work and u can manually power on off the unit but not with remote - why? Can I reset the remote?
Most remote controls use a conductive carbon paint on the underside of the button to make contact with the circuit board. The paint on the power button is probably worn out. You can get carbon or silver/carbon paint to repair it. Search for "keypad repair" to find the right stuff. I've used Chemtronics CW2605 to fix a number of items. The hard part is unsnapping the cover pieces of the remote control without breaking the locking tabs that hold it together. Just to make it interesting, some manufacturers hide a screw in the battery compartment or under the label (feel for a screw hole under the label sticker on the bottom of the remote control; if there is one, carefully cut a hole in the label over the screw hole rather than trying to peel off the label).
Chemtronics CW2605 Circuit Works Rubber Keypad Repair Kit Bdent com
Once you open the kit, it has a limited shelf life. You might as well touch up the channel and volume control buttons while you have the remote control open.
Oct 18, 2017 | Yamaha Audio Players & Recorders
I need a user manual for a Westinghouse dishwasher SB921SG Button labels all worn off
Try www.westinghouse.com.au main site and search your model. I've already done it and yours is listed, scroll to manuals.
Nov 04, 2014 | Dishwashers
I have a Bosch SHX46A05UC/33 5-cycle dishwasher whose labels on the cycle buttons have also worn away. While the Macmarkus post was helpful b/c I have some of the same buttons, can you tell me the labels...
Some SHX46A washers have 4 cycles and others have 5 cycles.
I'm fairly sure your model has the hidden buttons on the top of the door and you stated you have five-cycle buttons, in which case they will be as follows.
1. Top Rack only cycle or Sanitize
2. Power Scrub Plus
3. Regular Wash
4. Delicate Wash
5. Rinse and Hold.
These buttons are also used for cancelling a wash cycle. Hold down "Power Scrub Plus" and "Delicate" at the same time to cancel a cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration (from left to right) will be:
1. Power Scrub Plus
2. Regular Wash
3. Delicate Wash
4. Rinse and Hold.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Nov 21, 2010 | Bosch 24 in. SHX46A05UC Built-In...
Gaps in barcode with Zebra S4M
By gaps, do you mean a "void" area ? Over time, the elements on the printhead will wear down and finally they won't transfer heat to the ribbon. This causes a gap or void area. Usually the elements go out one or two at a time. If the area that is worn out is supposed to be printing bars for the barcode, this will cause the scanning problem you are experiencing.
The best way to see if elements are worn out is to design a label that has a thick solid black line across the label or a solid black box. You will see white vertical lines in the areas where elements are worn out. Another method would be to use the widest and longest label you have and print a 'pause" test label. This is done by turning off the printer, pressing and holding on the PAUSE key while turning on the printer. Hold the pause key for 10-15 seconds and when the printer is done with it's power on self test, it will start printing out a test pattern label which includes a nice black area where you can look for the white vertical lines.
Hope that helps !
Mar 30, 2010 | Zebra S4M Thermal Label Printer
Mitel 5212 - Worn out numbers
Hi dude...i guess u have to create one..no way to buy from mitel
Sep 18, 2009 | Mitel 5212 IP Phone
I need the code to program my JR400 & my Toshiba TV
I found a manual online , complete with pictures of the remote , buttons labeled, and program codes.
http://www.remotecodelist.com/remotes/jenson/JR300c.pdf
May 28, 2009 | Jensen JR400 Remote Control
White film on glasswear.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 08, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHV66A03uc built in
There is no easy repair on a Bosch dishwasher. I guess Bosch figured it would run forever. To replace anything (except the wash motor start capacitor) you will have to remove the dishwasher, flip it upside down to do most repairs.
Regards;
reg501
Jul 02, 2008 | Bosch Dishwashers
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher Logo
538 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
