Question about JBL CREATUREIIWHITE Computer Speakers
One speaker doesn't function at all, no little green light, no sound. The speaker with the volume control works fine, I can adjust the volume, everything's peachy. Other than jiggling the wire where this faulty speaker connects in, is there anything else I can try? Is there something specific I can look for if I open it up?
    Guru:
  • 2,178 Answers
Check the impedance or resistance of the speakers with an OHM meter - should be around 4 to 8 ohms. If you don't get a reading, its bad.
Posted on Oct 24, 2010
Testimonial: "Thanks so much - I was able to check this last weekend and barely got a reading over one; I'm putting them up on Craigslist for free."
SOURCE:
They worked for a long time, now all the sudden they aren't working. The main speaker it's powered on; however the green light is no longer lit and no sound is coming from them. Checking the...
possibly corrupted or missing sound drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 29, 2011 | Altec Lansing ACS 54 Computer Speakers
Why doesn't my sound card work?
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 22, 2011 | Diamond Multimedia XtremeSound 7.1...
My compaq 511 laptop's speaker doesn't work? What should i do?
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
Jul 19, 2011 | Compaq Audio Players & Recorders
Bose Desktop Speakers: not working, little blue light no longer comes on. Transformer OK.
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Bose Audio Players & Recorders
My x-230 dont work-the power is on the green led light is on but no sound.
hope this helps
Jan 18, 2011 | Logitech X-230 Computer Speakers
It shows the speakers are on but no sound
If you have an extra headset around, plug it into the same place the speakers are plugged into, if it works, your speakers are bad (or check to make sure the power light is on on them and that their volume knob is turned up).
If you still do not get sound, click on your little volume/speaker icon by your clock, then click 'mixer' at the bottom of it (Windows 7 hopefully?). Make sure the different volume controls are turned up because sometimes one low one will affect the entire system.
(If Windows XP, right-click the speaker, then 'Open Volume Control'. Adjust until you hear sound.)
Dec 08, 2010 | HP JBL Platinum Computer Speakers
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
I can hear my daughter when we skype but she gets no sound from me.
When you are in a call, find the little down arrow beside the call time near the bottom of the call window. Choose Sound Settings...
Find the green volume indicator under Microphone and make some noise. If it lights up and moves, your mic is working fine. Adjust the volume of the microphone by dragging the speaker slider left or right.
If the indicator doesn't move or light up, try choosing another device from the Speakers dropdown list. If you still can't make yourself heard, repeat this for all the devices.
If this doesn't help, reinstall your audio (sond card) driver software.
Best o luck
Jun 28, 2009 | Logitech Quickcam Chat Webcam
Speakers are plugged in correctly, lights on but still no sound
Check your output jack again and make sure its on the green jack
and also check your speaker wires, if okay then check this;
For Windows XP;
  1. Go to Control Panel
  2. Sounds and Audio Devices
  3. On the Volume tab under "Device volume" check that sound is NOT muted
  4. Adjust volume control
  5. Check "Speaker Setup" under "Speaker settings" under the "Advanced" button
For Vista:
  1. Control Panel
  2. Sounds
  3. Select Speakers then properties
  4. Make sure device is enabled
  5. Test sound
  6. Adjust volume controls
Under Device Manager make sure that under your sound card that you dont have a yellow exclamation. Yellow exclamation indicates you need to install the correct driver.
Jan 18, 2009 | E-Machines T6420 PC Desktop
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
JBL CREATUREIIWHITE Computer Speakers Logo
165 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
