Question about Toshiba NB205-N210 Netbook
My Toshiba Mini NB205-N210 would not turn on intermittenly for about a week. Now it won't turn on at all. The fan comes on for about 3 seconds and then goes off. The power button stays lit but there is nothing on the screen and no other sounds
  • Toshiba Master
  • 6,487 Answers
Base from the description of your problem this can be a issue with a motherboard failure or processor failure that can be cause by overheating.
What you can do here is to open the laptop and then take the RAM out and also check for any burn sign on your motherboard and also clean the golden teeth of the ram and put it back in and check if still same problem. Because if still same problem this is a clear sign of motherboard failure.
Posted on Oct 24, 2010
  • m_seeraj Nov 29, 2010
    Thank you for this solution! I have been experiencing the same problem with my nb205 which was bought in August 2010. I've been trying to contact Toshiba regarding the warranty but no success. I live in Trinidad (my mum bought the netbook in Canada), know that I know what may be the problem, I will have it checked out here
SOURCE:
Need to connect to a projector with the Toshiba NB205 and not getting output.
try the Window key, which is to the left of the ALT key. and the P key at the same time. Then choose duplicate
Sep 30, 2014 | Toshiba NB205-N210 Netbook
How to get to toshiba nb205 bios
Hold down the Esc key and press and hold the power button until the on/off light on the system indicator panel illuminates (green) for approximately one second. When the following message appears on the screen: "Check system, Then press [F1] key," press F1. The System Setup screen appears.
If that doesn't work, try powering on the laptop and when the Toshiba splash screen comes up, hit F2 or F12.
One of these methods will get you in to the BIOS setup.
Jun 10, 2014 | Toshiba NB205-N210 Netbook
Keyboard not working properly
A keypad overlay may be on. If the numlock light or cursor control
mode light is on, press Fn + F10 to turn off the cursor control mode
light, or Fn + F11 to turn off the numlock light.
Nov 16, 2011 | Toshiba NB205-N210 Netbook
My toshiba nb 305 wont start up, do you have any idea why? i was typing when suddenly it turn off, i tried to to turn it on but only the "on" button will power up but the screen wont start. after...
@fitz_quinto
Try to do the following:
1. Remove the battery
2. Press and Hold the power button for 20secs (this will drain the power out of the computer)
3. Insert the AC adapter and turn the unit ON
If the above procedure won't work, this is a sign that the computer's motherboard might have gone bad and you need to have the unit serviced. If you're still under warranty, call 1-800-457-7777 (for US) and 1-800-663-0378 (for Canada).
Good luck.
Sep 11, 2011 | Toshiba NB205-N210 Netbook
I got toshiba nb205 as i get error A PROBLEM WITH COOLING SYSTEM HAS BEEN DETECTED RETURN IT FOR SERVICE IMMEDIATLY i get its fan changed now its fan is in running condition and i am also using cooling pad...
hmmm, you could try booting into bios (hitting del key at bootup) and see what the internal temp readings are. Laptops have tricky cooling schemes that usually rely on one fan and heat pipes. If I were you I would backup my data and take it to a qualified laptop repair shop.
Nov 02, 2017 | Toshiba NB205-N210 Netbook
I've had Toshiba Netbook NB-205 for a year, and the display won't show. The fan will come on for a like two seconds and then cut off. If I need to replace the fan, then I'm fine with that, but if there's...
Try removing the battery and starting it up with only AC power.
Sometimes it doesn't charge properly and will turn off after a second. Removing the battery will sometimes fix this.
Make sure you are getting charge lights as well. If the AC adapter isn't working anymore, it can cause exactly what you're experiencing.
Please leave feedback if you found this helpful. Thanks.
Mar 18, 2011 | Toshiba NB205-N210 Netbook
I purchased a Toshiba NB205 as a second owner. There are two BIOS already on the computer locked with passwords. I can log on as a guest but can not make changes to anything. Please help me Get rid of...
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot.
Or try default password Toshiba
Good luck
Sep 14, 2010 | Toshiba NB205-N210 Netbook
Tosheiba Netbook NB205-N210 2 GIG, upgrade to Windows 7
I personally have not but if you are concerned how it will run, you should be fine, windows 7 is very efficent on resources.
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
    These are system specs so if you exceed these then your laptop will run great.
    Hope this helps
Mar 20, 2010 | Toshiba NB205-N310/BN Netbook
Toshiba NB205-N210 Netbook Logo
250 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
