How do you remove the agitator from a Simpson Genesis 505 washing machine
    Top Expert:
  • 867 Answers
Remove the link trap/Fabric Softener dispenser from the middle. You will then need a 10mm Socket and a long extension (or 2), undo the bolt in the bottom an the give the agitator a good pull (they can be REALLY tight) if the agitator still won't move put some really hot water into the machine until it covers where the bolt is/was and leave for 5 mins then try again.
Posted on Oct 25, 2010
2 Suggested Answers
SOURCE:
  • 1294 Answers
SOURCE: My washing machine is not draining
You can try this: It's for the Kenmore/Whirlpool models..
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels, a good big plastic bag or a wet vac to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Posted on Apr 03, 2009
How to remove/replace drum Simpson genesis top loader
Which drum? Inner spin drum or outer plastic drum? Why do you want to remove/ replace it? Some decent details may help you get an answer.
Aug 10, 2017 | Simpson Washing Machines
Simpson washing machine
you need a 10mm socket and some extensions and a ratchet take the fabric softer filter out and undo the ,bolt at the bottom of the agitator and lift out
May 28, 2017 | Simpson Washing Machines
Simpson agitator
This is usually caused by a faulty capacitor failing that a broken cluth pawl
Sep 26, 2017 | Simpson Washing Machines
Brake band for Simpson Genesis 505 heavy duty washing machine
www.searspartsdirect.com or www.applianceparts.com. If the brake is internal with the gearbox, chances are the only way to replace the brake is with a new/rebuilt gearcase.
May 10, 2012 | Simpson Washing Machines
Hi, i have a simpson genesis 523 w/mchn the agitator is not working,only rotates in one direction,(all other actions work fine) are parts available to fix myself .regards peter
peter mark here have s/son genesis 505 with same problem will contact you if i find an answer to my problems as it must be same problem [email protected]
Jan 17, 2011 | Washing Machines
Apr 03, 2009 | Washing Machines
Simpson 175 HD washing machine Programme keeps stopping Is it the timer or some other problem
image_bubblequestion_04.gif Can you please identify the problem with my washing machine?It appears all the functions of my simpson 175 washing machine work normally except the agitator only moves briefly and harshly for between 1 and 2 seconds.
Simpson 175 HD (Dual Action Agitator) Washing Machine.
1517 5M40 A 28 June 1990
Jul 12, 2008 | Washing Machines
Washing Machines Logo
956 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
