Question about Memorex MLT3221 32 in. LCD TV
Sound but no picture - Memorex MLT3221 32 in. LCD TV
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Oct 24, 2010
SOURCE:
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
Tip
SONY GRAND WEGA ERROR CODES AND WHAT THAY ARE
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
on Apr 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
No picture no sound
Last night i set childlock in my nikai ( NTV34010) tv set and tuned off by remote control.Then after some time later i tried to turn on tv but there is no sound and no picture.
will u please help me to solve it out.
Dec 02, 2007 | Panasonic CT-36D32 36" TV
Playback movie pictures or sound
Movie pictures can be played back with the camera, but not sound. However, when the camera is connected to a TV, both movie pictures and sound can be played back. For playing back movie pictures or sound on a PC, the QuickTime™ 4 is required.
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
Memorex MLT3221 32 in. LCD TV Logo
812 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
