How do I see the hole picture on my Philips match lll line. Black corridors on each side cuts away the sides of the picture. /t
  • 1,662 Answers
You may actually be looking at the entire picture. The newer televisions have a 16:9 aspect ratio (16 units wide for every 9 units high). The older sets had a 4:3 aspect ration, and a lot of material was made for the 4:3 screens. There are three ways to look at this material on a wide screen set: use the "shadow box" you describe, stretch the picture sideways to fit the screen, or expand it to fit width and lose the top and bottom of the picture. Your choice depends on the material and your personal preference.
Now, if you know you are looking at wide screen material, you need to correct a setting in the view format options. These settings go by various names in the instruction manual and on-screen menus - "resolution", "aspect", or "display format" are common. I haven't seen the menus on a Phillips set, so I don't know what term they use.
Posted on Oct 24, 2010
6ya staff
SOURCE:
Bernina buttonhole 730
Use your ruler and measure your button. Then transfer those measurements to your garment.
Use chalk to mark the center cut line of your button hole. Mark the end or stop point of the button hole per the measurement.
Practice on a scrap of the same fabric before you begin on your garment.
Set your machine the satin stitch zig zag at a fairly narrow width.
Begin satin on one side of the center line of the mark. Slowly stitch down that side until you get to the end. STOP. Widen your satin stitch to the max. sew about 1/8" and stop with the needle down on the opposite side to your first line of stitching. Turn the fabric, narrow the stitch to match original satin stitch. Sew slowly down the other side of the center mark. STOP, lengthen the stitch, sew 1/8" then do a couple back stitches.
That's one way. Another older way is to sew 2 or tree straight stitch lines around the center line. Remove then use a hand rendered button hole stitch after you cut the hole.
Oct 27, 2013 | Husqvarna Sewing Machines
Drive medical phoenix 3 backup alarm
It is very easy to quiet your backup alarm. All you need is a small philips [+] screw driver and a piece of electrical tape about 1 inch square. Raise the "hatch cover" under your feet by removing the two small phillips head screws on either side of the raised edge. Locate the small round black son-alert taped in line with one of the wiring harnesses. You will see an opening in the center of one side of the Son-alert. That is where the "beep" comes from. Prove you have the correct part in hand by turning on your key switch and pressing the horn button, first with your finger over the hole in the son-alert and then without your finger covering the hole. You will hear a very big difference if you have the right part. Now you can put your piece of electrical tape in place over the hole and try it again. It will be much quieter. DO NOT CUT THE WIRES LEADING TO THE SON-ALERT! If you still want it quieter use a thicker, more sound deadening cover over the hole, but cutting the harness to disconnect the sona-alert entirely will lead to unintended consequences.
Jan 30, 2012 | Drive Medical Phoenix 3 Wheel Compact...
How do u restring a black and decker 7.0 amp dual line trimmer?
Take a length of about 6 foot of line, kink it in the middle and pass this through the hole in the spool. Wind the two lengths of line around the spool in their own divisions and in the same direction. The direction of wind is embossed in the reel and the line should be wound tightly and held all the while. When you have about 6-8 inches left in your hand, bring the cover up to the spool and carefully pass the two ends of the line through the holes, push the cover all the way over while pulling on the two pieces of line and ensuring that the lines stay on their own side of the division on the spool. Fit and tighten the bump nut and trim the lines to just about the cut-off blade.
The lines should trail out of the holes in the direction of the machine's rotation. Try cut with the tip of the line as much as possible. Cutting nearer the drum flexes the line and will lead to early breaking of the lines. Run the motor at a constant speed and rather move the cutting head in and out of the weeds to affect a deeper cut
Jul 16, 2011 | Black & Decker Garden
I punctured my gas line. I would like to know what I need to do to repair it. I have a 98 Kia Sephia, 1.8 liter engine, automatic.
If it's just a hole on steel line get a piece of rubber fuel line and 2 gas line clamps. Cut the line at the hole and clean it off with a piece of emery cloth or sandpaper. Slide the rubber hose and clamps onto one side and then over the other.Place the clamps on either side of the cut and tighten.
If it's plastic line then there is a brass compression fitting you can use. Measure the size of the line and get the fitting to match. Cut the line and clean it off. Slide one nut and the ferrule onto the line and thread it onto the union. Do the other side and tighten but not too tight or you will compress the line. Start the car and check for leaks. Tighten only until the leaking, if any, stops and quit.
Hope this helps.
Apr 24, 2010 | 1998 Kia Sephia
I have a weedeater brand weedeater and need to know how to take the spool off so I can wind more line on it?
if its the newer type all you need to do is grab the black knob at the bottom of the trimmer head and pull it carefully straight towards you and it should pop off
wind line on the spool in the direction the arrow shows you there is a small hole you put the line in to start the line before you wind it it is labeled .065 or .080
wind about 10-15 feet of either .065 line or .080 line and lock the line in at the edge of the spool and thread the excess thru the hole and push spool back on and pull each line until it unhooks from where you locked it in .
this is the directions to the weedeater heads and spools mostly used on this product.
if its two lines then pull out 20 feet of new line cut it and put the two cut ends side by side and insert the cut ends into their respective holes in the spool and wind in the direction of the arrow until you wind to the loop then cut the loop lock your lines into place and thread it thru both holes keeping the lines kind of tight and push the spool onto the housing as it snaps in pull each line to unlock it from where they were held so the bump feed will work.
hope this helps you
Jun 08, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Screen Shift PLZ HELP
burn in run  a white screen
Jun 06, 2009 | Philips 42PF7421D 32 in. LCD HDTV
Head of philips norelco speed xl fell apart.
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
Hope this helps!
Dec 20, 2008 | Philips Norelco 8175XL Electric Shaver
Philips 27PT6441/37
There is a install kit 483531057673 for this model when the set is dead. The kit will contain 7404 and the Horizontal Driver Transformer 5402 along with resistors that will limit stress on 7404 and includes complete instructions
May 03, 2008 | Philips 27PT6441 27" TV
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
