Question about Asko 1375 Dishwasher
Asko 1375 unit will not wash drains and fills ok  motor at back of unit runs well. Suspect impeller   Does motor have to come off for impeller replacement?? My 1375 is leaking a bit, looks like the seal which was mentioned in the impeller repair case,may be the problem? The other problem I noted was a clogged screen at the bottom of the dishwasher which is on the suction side of the pump, the screen had calcium buildup etc. I cleaned it off with vinigar and reran the dishwasher seemed ot fix the draining and wahing problem but still a bit of leaiking into the pan below the pump...may not be a problem, suspect a seal problem. Will look further into the problem if the leak persists. Thanks for the help Al
    President:
  • 2,712 Answers
Do you mean to say that the washer does not go into the wash cycle at all, or washes poorly?
An answer to both can be found HERE.
This article HERE will help you determine if your impeller needs replacement.
Hope that helps. If you need further clarification, or have additional queries, please post back. If you are satisfied with my response, kindly take a moment to "Accept" my solution. Thanks.
Posted on Jun 08, 2008
    Genius:
  • 2,035 Answers
May be the drainpump that has something stuck into it. Check that
Asko 1875 had a new main board, wax motor and temp thermistor fitted 6 months ago. now thw machine pumps in the water but does not wash what could be the problem
Hello, welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko 1875 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, unfortunately.
First though, do you hear a quiet sound of the wash motor starting once the unit has completed filling with water ? And be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues.
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely.
This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet...you may opt to call in a pro.
I'll watch for your reply and try to help in any manner I can.
Regards,
Macmarkus :)
May 20, 2011 | Asko D1876 Dishwasher
Dishwasher is not washing the dishes. Motor sound like it comes on, Water is drained aout and put in but it appears no rinsing or washing goes on. Don"t hear the arms rotating either. It goes thru the...
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1776 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, as you mentioned. What you may not know, is the impeller itself is not serviceable, the entire motor/pump must be replaced unfortunately.
Before declaring it is indeed a motor/impeller issue, you said you hear a quiet sound of a motor starting once the unit has completed filling with water right ? Be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues. (try placing both spray arms at 12 o'clock position and placing a cup upright in the top rack. If the arms move and the cup fills, you've got circulation...if neither, you don't)
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump or severed somewhere between the motor and control, maybe where the door pivots during opening...but not likely.
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet. Check those other possibilities first and tell me what you find.
I'll watch for your reply.
Regards,
Macmarkus :)
Apr 19, 2011 | Asko D1776 Built-in Dishwasher
The spray arms on my Asko 1716 dishwasher do not turn - water enters the unit and drains easily, and the heating element also seems to work. The filters and sump are clear, as are the air gap and the holes...
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1716 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, as you mentioned. What you may not know, is the impeller itself is not serviceable, the entire motor/pump must be replaced unfortunately.
Before declaring it is indeed a motor/impeller issue, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? And be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump obviously it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues.
Regards,
Macmarkus :)
Mar 09, 2011 | Asko 1375 Dishwasher
It doesn't sound like the dishwasher jet arms are spraying water and the dishsoap was still on door at end of cycle.
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1716 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, unfortunately.
First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? And be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
Regards,
Macmarkus :)
Jan 29, 2011 | Asko D1716 Built-in Dishwasher
After filling with water it fails to wash.Washers inside the unit are not spinning around.
Hello, Welcome to FixYa. Based on your description and provided the dishwasher is indeed 1) an Asko D1706 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, unfortunately. First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? ( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues ) If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design. What happens typically is the ball-bearings from the upper rack holders ( the holders which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor. Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet...you may opt to call in a pro. I'll watch for your reply. Good luck. Regards, Macmarkus :)
Dec 10, 2010 | Asko D1706 Built-in Dishwasher
On my model 1475, the washer arm doesn't seem to be working and the wash cycle isn't working. It still fills, drains, and goes to the heat cycle. . .but we don't think it is doing the actual washing. ...
Hello, Welcome to FixYa. Based on your description and provided the dishwasher is indeed 1) an Asko 1475 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, unfortunately. First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? ( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues ) If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design. What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor. Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet...you may opt to call in a pro. I'll watch for your reply. Regards, Macmarkus :)
Nov 26, 2010 | Asko 1375 Dishwasher
The 1358 dishwasher does everything (pumping, water, heating, drying) but it does not really wash and dishes and dooe remain dirty.
Hi, Welcome to FixYa. Based on your description and provided the dishwasher is indeed filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump. First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? ( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues ) If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design. What happens typically is the ball-bearings from the upper rack holders ( the holders which are plastic, hence fatigues due to heat and fall apart letting the ball bearings loose ) come out making their way into the sump, hence breaking the wash impeller from the motor. Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair...I'll watch for your reply. Good luck. Regards, Macmarkus :)
Nov 11, 2010 | Asko 1385 Dishwasher
MY DISHWASHER WONT KICK INTO WASH CYCLE CAN HEAR THAT IT WANTS TO BUT DOESN'T ..IT WILL FILL AND DRAIN AND DRY...CHECKED DRAIN AND FILTER CLEAR
Welcome to FixYa.
( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Viking...built by "Asko"...are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver )
What happens typically is the ball-bearings from the upper rack holders ( which are plastic which fatigues due to heat and fall apart ) fall out making their way into the sump, hence breaking the wash impeller from the motor.
Good luck,
Macmarkus :)
Aug 26, 2010 | Viking 24 in. Professional Series VUD141...
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Jun 22, 2009 | Asko 1375 Dishwasher
Asko 1375
May be the drainpump that has something stuck into it. Check that:)
Nov 23, 2007 | Asko 1375 Dishwasher
Asko 1375 Dishwasher Logo
204 people viewed this question
Top Asko Dishwashers Experts
Mike Cairns
Mike Cairns
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
