Question about Acer NSK8458AN Keyboard
My Num Lock key will not come on after I dusted the keyboard.
    New Friend:
  • 6 Answers
Pick it up, unplug it from the usb...give it a good shake, then put it down, plug it back in and see if this works. You might even try restarting your computer after you did the previous and see if it might work after that. When all else fails, try it on another computer and if it is working on another computer, try plugging it into a different port. I hope this helps, cheers.
Posted on Oct 24, 2010
SOURCE:
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
My numeral key are not working[123456789 right side of key bord]
Step 1:
On some laptops it may be difficult to locate and activate the "Num Lock" key. Depending on the laptop, it may be hidden as a function where you have to press two keys. Most of the time, a laptop keyboard is just like a full desktop computer keyboard and it has a "Num Lock" key on it. Most people do not realize the "Num Lock" key is on their laptop keyboard because it barely serves a purpose without a full numeric keypad.
Press the "Num Lock" key on the laptop at the top, right of the keyboard. Press the "Num Lock" key and the "Fn" key simultaneously if the above does not work. Press "Fn" and "F11" simultaneously on the keyboard to activate the "Num Lock" function. Some laptops, like Toshiba, do have a "Num Lock" key. The shortcut for G3 Mac laptops it is "F5," and on G4 Mac laptops it is "F6."
Feb 07, 2013 | Computers & Internet
Why would CNTRL-ALT-DELETE not work when I need to lock my computer? Where is the Num Lock located on this keyboard?
Num lock is located juz above the 7 num key on the num keypad. Try using control alt del key on another system and check if it works or not.
Aug 25, 2011 | Logitech MX 5500 Revolution Keyboard
How to activate the num keyboard? Can´t find the Num Lock key.
Welcome to fixya,
The num lock key is on the top right of your keyboard where you see the numbers.
Hope this Helps.
Dec 18, 2010 | HP Pavilion dv7-1130us laptop
My asus keyboard is writing some keys as letters and others as numbers - tried restarting and no change (I am using a USB one now)
It sounds like you have your Num lock on. To disable the Num Lock either just hit the Num Lock key (its usually on the top right hand side of the keyboard) or hold down Fn and then hit the Num Lock key.
If you need more assistance please post back.
Regards.
Jan 06, 2010 | ASUS 90-A4C1K1000 Keyboard
Typing numbers instead of letters
Your keyboard has "extra" keys:
* print-screen / system-request
* scroll-lock
* pause / break
* num lock
Press that "num lock" key.
For a laptop keyboard, you may have to hold down the 'FN' key,
at the same time that you press "num lock", to enable/disable this function.
Jan 02, 2010 | Gateway 7001433 Keyboard
Keyboard keys that have purple numbers are locked. Can't type.
Your "Num Lock" is on.
Look for the num lock key (it's similar to the "caps lock" key in function)
If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Sep 20, 2009 | Compaq Keyboard
I am having to hold down fn to get my keyboard to properly type letters i pressed num lock and it still isn't fixed.
go to start menue>
all programes>acccessories>accessibility
then on "screen keyboard"
there you will see the numlock button hilighted.
single click on num lock key.
ur problem is solved.
dont forget to vote
Sep 14, 2009 | Compaq Presario 700 470024-192 Notebook
How do i get the keyboard to type the letters instead of the numbers
hold the fn and shift and num lock keys down - this reverts to normal keyboard
Jun 22, 2009 | Acer NSK8458AN Keyboard
Number 9 inside a lock symbol on the keyboard and computer unresponsive
press num lock /num LK/scroll Lk.Find any of those key on your keyboard.it solve your problem.If .in Dell Latitude D600 the num lock/num Lk/scroll Lk is above F11 key.
  • after solve it,don't forget to visit me here
Jun 10, 2009 | Dell 0Y3740 Keyboard
Acer NSK8458AN Keyboard Logo
Ekse
Alun Cox
