Question about Sony Cyber-shot DSC-W70 Digital Camera
The flash doesn't work any more and i face with error
    New Friend:
    Problem Solver:
  • 14 Answers
Defective flash unit
Posted on Oct 25, 2010
SOURCE:
Error 05 flash doesn't pop up
spray a very very small amount of WD40 on the hings of pop up flash (use the thin RED spray tube)
Nov 17, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
Moultrie i40 digital game camera will not flash
run diagnostic test and cover sensors with thumb...may have to shade IR flash array to see it glow red...menu may start countdown...if flash doesn't glow you will get a 020000 error(flash/flash charging error).To fix you need to remove batteries,sd card,rubber plug from remote slot, 5 screws from face;lift out face and turn over. Remove 4 screws, keeping separate from other screws, from camera card and carefully unplug (3 plugin connectors) and carefully lift camera card out..no soldering required up to now..2 conductors,a red and a black, connect to the flash array at one corner...these go to the sensors on the face,slightly under main board...either the sensors are bad or the array is bad...getting replacements is the problem unless you can get them...I buy "as is" cams off eBay.
Dec 14, 2011 | Moultrie I40xt I40xt Trail Camera 50 Mp
Flashing protect code to unlock
There is no code to unlock it when your radio goes into protect. First check all of your speakers and speaker wires for shorts and/or grounds if you can. If they check out good try resetting the radio. If there is a reset switch, it will be a small pencil tipped depression on the face, or a small hole behind the face with a switch behind it on the sub assembly. If there is no switch, you can reset it by disconnecting the battery for a few seconds. If that doesn't work, you may have a bad output ic or volume control ic.
Aug 25, 2011 | JVC AM FM CD DET FACE CAR STEREO
I have a zoom error. When I turn on camera it just opens and shuts. What should I do?
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 04, 2011 | FUJIFILM FinePix J40 Digital Camera
By using the flash, I get a shadow around the right side of peoples faces, doesn't happen when not using flash, but color is not as good.
Are you new to photography? The flash emits an intense light and depending on where it is found on the camera in relation to the lens, it will cast a shadow on one side or the other. DSLR cameras solve the problem by mounting an external flash directly over the lens and high up so the shadow is less noticeable. If you take a lot of people's faces, you might want to explore "fill lighting".
Jun 24, 2011 | Cameras
I have a PIXMA MP 110 CANON and when i go to print it says CARTRIDGE IS JAMMED PRESS OK. The computer says it is a ERROR 5100 problem and press OK AND IT SHOULD WORK .but it doesn,t. The cartridges are...
You are facing e5 error which cannot be solved.
For Canon printer, if you refill about 4~5 times, especially color, the printer does not read that particular cartridge.
Well for solution? You need to replace the cartridge with new one.
Just blame Canon....
If you would like to save money, try refill kit by "ROADINK".
At least you can easily save $100 for color cartridge (facing e5 error after 4~5 times of refill)
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | Office Equipment & Supplies
I have canon 450 d i face the problem error 99 if i open flash it showing error 99 give me answer
error 99 means flash is stuck . pop the flash and when it clicks, you have to smack the side of the camera to make it pop open
Nov 23, 2010 | Canon EOS 40D Digital Camera
Trouble in my camera: no flash while taking photographs even though it is set in flash position. As on opening there comes a blinking like'E:919'& flash symbol. It arose 2days back when I just opened...
Flash capacitor doesn´t charge in a specific time. There may be more reasons. Camera remembers error state and do not use the flash even you turn it off and on. You can try to let it "forget" by resetting (initializing), but if problem persist, do not do it often, it may cause secondary problem.
Sep 01, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
26 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
