Question about Whirlpool LEQ9030P Dryer
My dryer is running fine but not blowing hot air, could it be the heater element?
    New Friend:
  • 85 Answers
Yes
Posted on Oct 25, 2010
5 Suggested Answers
SOURCE:
  • 83 Answers
SOURCE: maytag dryer not blowing hot air (2yrs old)
If the vent is blocked, it will not stop the heat, it will only restrict the air flow.
Generally a couple of things can cause the heat to stop.
Either the thermostat or the element.
I would first suggest the element.
It may be fatigued therefore the internal wire within the element becomes fragile and eventually breaks down. Although it is an electrical item, it is mechanically built and can fail.
In some dryers the element is held in clips.
These clips can cut into the element.
The thermostat maintains temeperature but again, it is mechanically built and can also break down.
If you are not capable of inspecting or troubleshooting the internals of the dryer (i.e remove the cover and look for the failurer), then have it inspected by a repairman. There is not too much that can go wrong with a dryer. The most expensive part wuld be the motor that spins the drum.
Posted on Sep 17, 2008
  • 67 Answers
SOURCE: Dryer will not blow hot air
first, check the entire exhaust pipe, most of the time the problem is there. every inch must be free of lint. to take apart most dryers: 2 screws hold on the bottom front panel. those screws are near the floor on the front. once that panel is off, you should see 2 more screws, this allows you to remove the main front panel (the one that holds the door) with that off, there should be 4 screws holding the front drum support on. with that off, you should be able to carefully remove the drum after removing the belt from the motor. to get the belt off, you have to reach in from the bottom and push the tensioner and slip the belt off the motor.
good luck!
Posted on Oct 28, 2008
  • 6 Answers
SOURCE: wont blow hot air
heating element failure 30 bucks and an hour of labor
Posted on Jan 14, 2009
SOURCE: Dryer blowing cold air only
older homes with fuses can have to fuses on the dryer circut-1 could blow and the dryer would run without heat
Posted on Jun 20, 2009
How I can bring back hot blowing air to my ken more dryer,which is blowing cold air.
CHECK THE HEATING ELEMENT WITH A MULTI METER, CHECK THE THERMAL CUT OFF AND HI LIMIT THERMOSTATS LOCATED ON THE HEATER. AND LASTLY ARE U GETTING A FULL 240 AT THE TERMINAL AND HOUSE OUTLET? IF NOT , U WILL HAVE ENOUGH TO RUN MOTOR BUT NOT HEATER
Feb 25, 2015 | Dryers
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
White knight tumble dryer cl847 not heating
-Possibly one of the heater element blow out.
-Timer switch assembly stuck in low position.
Good luck
Mai
Nov 21, 2013 | Dryers
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Dryer turns on, tumbles, and blows air, but not hot air
take off the bottom toe kick
look to the back left of the cabinet
you should see the heat element, inspect all the connctions, this model ahs a habit of burning connections
if all is ok it probably your heating element ive included the sears part number for you
37001134
its ver easy to repair this
the heater runs less than 30 dollars
Oct 08, 2009 | Maytag SDE3606A Electric Dryer
Wont blow hot air
Jan 14, 2009 | Dryers
Will run but heat up
When you say that it will run, is the heater element getting hot and is the blower on or off? Those are two distinct and seperate issues that I will need to know in order to assist you...Please get back to me with that information...
Oct 20, 2008 | Whirlpool LER4634J Electric Dryer
Maytag dryer not blowing hot air (2yrs old)
Sep 16, 2008 | Dryers
Wont blow hot air
check that you have 240 volts to the dryer terminal block
if so check the element and the element thermastats
May 07, 2008 | Estate EED4300SQ Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
