Question about Omega MARS-22 Remote Vehicle Starter with Keyless Entry
On 1991 toyota celica the remote starter workd for about a few seconds then stops its a marrs 22 alarm system
    New Friend:
  • 21 Answers
Find your Mars Box and then.....
Here is the link to get the manual. http://www.caralarm.com/manuals/MARS/MARS-22.pdf
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
Posted on Oct 27, 2012
SOURCE:
How to turn on my alarm on Toyota celica 1997
There was not a factory installed alarm for this car, any "toyota" security system would have been instaled at the dealer or the regional distribution port depending on what region the car was originally sold from. Do you have a remote for the system? Also check for a red valet button on the dash that can be toggled on/off. The port systems are also known for toggle switches located on the driver kick panel or under the driver dash. If you don't have a remote and manually unlocking the car from closed driver door will not disable the system you will have to locate the toggle/valet switch.
Dec 19, 2016 | 1997 Toyota Celica
1991 toyota celica starts but alarm wont turn off
Most car alarm securty systems can be silenced by inserting key into door lock and cycle it. Runs of a simple switch that's attached to lock cylinder.
Oct 26, 2017 | Toyota Celica Cars & Trucks
Got a 1994 toyota celica gt will start and run fine oneday and the next just sits and will turn over but doesnt start???????
Hi do you have spare key and remote , i have worked on few cars with similar problems it could be worn ignition switch , transponder problem or alarm system
Jul 14, 2012 | 1994 Toyota Celica
Changed battery in 1993 Toyota Celica. Alarm goes off and will not allow car to start.
You will have to reset the security system. Call the dealership and they can give you the code. You need your vin# You might have to go there personally. It just depends.
Feb 17, 2011 | 1993 Toyota Celica
Toyota 1.8 vvti celica key thob alarm problems
THE FACTORY KEY FOBS ARE IDENTIFIED BY
THE NUMBER OF BUTTONS AND THE NAME ONE THE BACK
IE: DENSO, TRW, TOYOTA,NGK OR BOSH
BUT THE REMOTE THE YOU DISCRIBE SOUNDS LIKE YOU HAVE AN AFTER MARKET REMOTESTART/ ALARM SYSTEM
Oct 23, 2009 | 2000 Toyota Celica
I lost my keys for toyota celica 1996 year,i had another 2 keys and but without remote,now when i opening door with keys alarm turns on and after that when i startin engine after 1 minutes alarm turns...
Look under the steering column ,now normally on an after market alarm installation ther should be bunsh on wire tied up with plastic zip-ties --looks like a mess , and in that a mess look for a square relay about 1" sq. Unplug that. That will isolate the alarm system.Good Luck
Oct 12, 2009 | 1996 Toyota Celica
Toyota Celica '91 ST184R - Key fob remote does not unlock the car
The ST18x didn't come with a factory fitted alarm, so this is going to be more general.
Your alarm will have a manual disarm somewhere. If you have a small cylindrical device with your keyfob, there will be a receptacle somewhere near the drivers seat. You need to open the door and press the two items together. If not, you may have a button hidden somewhere around the place. In this case the procedure is usually to hold the button while you insert the ignition key and turn it to the ON position.
Some alarms have a small round key. If your alarm has one, or if your keys came with one and you didn't know what it was for, you can open the bonnet, pop a little cover on the alarm box (it will be bolted to the firewall, usually on the right hand side as you look at it) and turn it off until you can get it repaired, or get a new one fitted.
If none of this works and your alarm is an alarm only and not an immobiliser, you can simply open the bonnet and cut all the wires going into the alarm. If it is also an immobiliser, don't touch anything unless you're handy with a soldering iron and multimeter and have a few hours spare. (You would need to pull the cover down from under the steering wheel, then start taking electrical tape off the big block connector with thick wires, and then start rebuilding the wiring that's been chopped to make way for the immobiliser system on a colour-matching basis.)
May 17, 2009 | 1991 Toyota Celica
Starter problem on 1991 Toyota Celica GTS
starter drive might be bad... fly wheel bad spots poss bad starter you sure its not just clicking???
Dec 29, 2008 | 1991 Toyota Celica
1991 toyota celica ignition off problem
1.Check ignition switch
2.Check alarm -possible short between ignition switch wires
Jul 04, 2008 | 1991 Toyota Celica
Omega MARS-22 Remote Vehicle Starter with Keyless Entry Logo
219 people viewed this question
Top Omega Juicers Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you an Omega Juicers Vehicle Part and Accessory Expert? Answer questions, earn points and help others
